Copy A Layout File, New Plan File
ACADuser
I have a project & need a copy of the layout file for alternate version.
So I copy the layout file and name it <House Name>B.layout
I copy the PLAN file to <House Name>B.plan.
Now I want the layout file to associate with the new plan file not the old file.
Do i have to delete ALL the views sent to layout and recreate all views from the new plan file?
Or is there some magic button? :)
THANKS FELLAS, THE GLOBAL LINK OPTION DID THE TRICK.
Oops caps
OK this layout was used on another file I I can not delete the link from that original file.
The relink took care of the previous file but the original plan is still linked.
How to purge it?
Yes & that changed the plan in question to the correct plan. All views updated to the new plan.
In that dialog box I see another plan file I had used when I created this layout file originally.
I just reused the layout file as it had all the notes I needed but some how it is still attaching the original plan file.
OK I solved the issue. Found a CAD detail I created in the original plan (foundation detail) & sent to layout so it stayed with the layout file.
Deleting it after making a block & sending to library. The file detached.
Inserting the saved detail block and I am back in business.
Thanks All
