HighwayMan55 Posted February 11, 2016 Share Posted February 11, 2016 A couple of questions on this post... 1) How do i change the material on this top piece of my stairs? When I do it changes the whole wall. 2) How do I trim the trim to the height of the floor? 3) Can I change the height of the trim? And lastly, can I can I select a different material for the trim than the riser? Thank you in advance! OurHouse.planFetching info... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 11, 2016 Share Posted February 11, 2016 Select the railing wall and apply a "Wall Covering" (10" high, -10" to bottom). -or- copy the "Wall Type" for that railing and add the riser material to the exterior surface. In reality, the riser is there but the Wall Surface material is over-riding it in the display. There's no way to specify a different material for the trim vs risers. We've asked for that but CA hasn't done it yet. Link to comment Share on other sites More sharing options...
HighwayMan55 Posted February 11, 2016 Author Share Posted February 11, 2016 On 2/11/2016 at 4:42 PM, Joe_Carrick said: Select the railing wall and apply a "Wall Covering" (10" high, -10" to bottom). -or- copy the "Wall Type" for that railing and add the riser material to the exterior surface. In reality, the riser is there but the Wall Surface material is over-riding it in the display. There's no way to specify a different material for the trim vs risers. We've asked for that but CA hasn't done it yet. Using the wall covering it spans the whole wall, not just the stair section. And copying the wall type covers all the stairwell walls. I think I will use a polyline, I seem to be getting good at using those to fake out things, lol. Link to comment Share on other sites More sharing options...
HighwayMan55 Posted February 11, 2016 Author Share Posted February 11, 2016 On 2/11/2016 at 4:53 PM, solver said: Check Riser Surface At Top Landing on the Style Panel. By "trim" I'm guessing you are referring to the Skirtboard or Stringer against the wall. You can turn it off and draw in your own shaped however, and with whatever material you like. Yes stringer, thank you. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 11, 2016 Share Posted February 11, 2016 Another option for getting the top riser material to show would be to just move the railing wall about 1" at that location so the riser is visible. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 11, 2016 Share Posted February 11, 2016 I would personally probably go with the polyline solid method and convert it to a material region for the issue with the top riser. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 11, 2016 Share Posted February 11, 2016 Sometimes if you back the stairs out a little ( but still be connected) will fix that. The stairs need to be in an exact location. They very easily can move. I usually lock them when they are good to go. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 11, 2016 Share Posted February 11, 2016 So, FWIW - here's what I did: 1. I broke the railing wall right at the edge of the Door Opening 2. I selected that wall segment and used Transform/Replicate to move it in the y direction 1/2" That allowed the riser surface to show because the wall surface was no longer in front of it. Link to comment Share on other sites More sharing options...
HighwayMan55 Posted February 11, 2016 Author Share Posted February 11, 2016 I just went with the polyline solid. I do have the riser surface at the top landing checked already. I attempted Joe, but I was unable to without missing up other walls. I've come to the conclusion that will not be able to "properly" recreate the way the house was built. But I can come close. Thank you all. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 11, 2016 Share Posted February 11, 2016 Fixed it just playing around, straightened a few things, added another break in the landing and brought it back from the upper floor just a tad. Edit btw your rail walls weren't aligned with the wall below also. Link to comment Share on other sites More sharing options...
HighwayMan55 Posted February 11, 2016 Author Share Posted February 11, 2016 On 2/11/2016 at 7:58 PM, DRAWZILLA said: Fixed it just playing around, straightened a few things, added another break in the landing and brought it back from the upper floor just a tad. Edit btw your rail walls weren't aligned with the wall below also. There is a 1" overlap of the top floor over the bottom floor, that's why they aren't aligned. I am doing a as built drawing of my house, and that's how its built for some reason. Link to comment Share on other sites More sharing options...
