ArchieD
Dimensions Grayed Out In 3D
Hi,
Could anyone quickly take a look at the file I've attached and tell me why my dimensions are grayed out?  Sometimes the numbers appear at first but when I move my cursor, they quickly turn into blocks of gray, and I can't seem to get them back.
Thanks!
You might want to attach the plan for a better answer, but on the surface, it kinda looks like it might be a video card issue.
Had the same problem here and yes, it was a video card problem.  When I upgraded to Windows 10, it set my video card to the on-board card in my laptop, not to the Nividia Card.  Changed that setting and all ok.
You might just want to use that NVidia card.
Thanks VERY much for the video card info.  I followed instructions to update my video card driver through Intel, and, while in the end it said I couldn't do it, somewhere along the way, my dimensions miraculously began appearing again!  Awesome!
I'm curious...did you just upgrade to Windows 10 recently? After upgrading to Windows 10 several months ago I experienced the same behavior. The video card driver update "failed"... yet completed successfully. And I believe its happened again since then on successive updates.
Restarting the computer will fix the issue as well. If you leave your machine on for extended periods, like I tend to do, restarting or shutting the machine down for the night will fix the issue.
    27645
    ChiefUserTyMN
    ChiefUserTyMN
  • Similar Content
    • By wjmdes
      Not sure if this was an issue in X11, but in X12, I added "FIELD VERIFY" to Trailing Text under Segments and it also added "FIELD VERIFY" into the extension next to the elevation.  Fortunately, in this case, that is fine, but maybe an issue in the future.
    • By Chiefusermickey
      Is there any way to force new objects such as a window, wall, or door to snap to the grid? I have my snap grid/snap unit set to 1". I would like for new items to be placed in the plan on a whole inch and not fractions. As it is I can drop in an object and the dimensions to it will be off the grid and not a whole number. I have to manually move the object to get the dimension to a whole number. I have attached an example of my problem. To many unwanted fractions.
    • By Christhebuilder
      I don't have the option for auto interior dimensions available in the dimension drop down menu. Am I missing a setting that makes its available? Auto exterior is there, NKAB is there, Just not auto interior. What am I missing?
    • By DeckQuestions
      I need my CA walls to match these drawn measurements, but I'm having trouble getting both the diagonal-wall-length and horizontal-wall-to-horizontal-wall dimensions to agree. I think it's because CA can't/won't automatically alter the angle of the diagonal wall.
      Is there a way to get everything where I want it without eyeballing and manually fine tuning the the angle?
    • By cjanderson66
      Does anyone have a good way of doing a dimension for an arc.  I was so used to AutoCAD's nice way that you could dimension an Arc/Radius easily and have not found one way to do it nicely that I like.  I would love for CA to have an Arc dimension child menu that would be customizable.  I would also like CA to have the the dimension feature a bit more customizable as well as I don't really like the arrows either and would love a bit more of an Architectural arrow.
