cliffy Posted January 15, 2016 Share Posted January 15, 2016 I am attempting to place dormers on the steep roof section of a Georgian Gambrel house. I am having trouble with the ceilings (See attached pictures). Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 15, 2016 Share Posted January 15, 2016 Is this an existing home or a home you intend to build? The dormer object ceiling is determined by way of its dialog box and in the case of a barn roof like you have, you may have to "explode" the dormers you have and manually edit them, especially if they need to encroach into the upper roof pitch (something that dormer objects are not automatically capable of. Please clarify your intentions. DJP Link to comment Share on other sites More sharing options...
javatom Posted January 15, 2016 Share Posted January 15, 2016 You may have intend the roof line to look like this but your roof planes are not lined up. That is why you are seeing a fascia board where the roof planes are trying to meet. Dormers react very strange when there are other problems in the roof system. Link to comment Share on other sites More sharing options...
cliffy Posted January 18, 2016 Author Share Posted January 18, 2016 This is a home I intend to build. Dormer roof ties in below second roof plane. Link to comment Share on other sites More sharing options...
cliffy Posted January 18, 2016 Author Share Posted January 18, 2016 Attached is a CAD Drawing of the roof i am attempting to build. it has been a challenge so any help on how to automatically generate this roof would be great. Link to comment Share on other sites More sharing options...
javatom Posted January 18, 2016 Share Posted January 18, 2016 I think you would have to create it manually not automatically. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 19, 2016 Share Posted January 19, 2016 I think it's possible automatically Set the different pitches in the wall DBX Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 19, 2016 Share Posted January 19, 2016 I think it's possible automatically Set the different pitches in the wall DBXYou are correct. Definitely doable this way. Did this pretty quickly by...-Setting the 4 end walls (2 upper and 2 lower) as full gable walls -Opening the wall DBX for the 2 lower side walls, and under the roof tab, giving the roof an extremely steep pitch and an 8" overhang. -Opening the wall DBX for the 2 upper side walls, and under the roof tab, giving the roof a shallower pitch and a 2" overhang. Link to comment Share on other sites More sharing options...
