sunnyseven Posted January 13, 2016 Share Posted January 13, 2016 Hi, Does it usually take hours to install the core architectural catalog? Also, does anyone know how to keep it from timing out if I'm not actively using the program? Thanks Link to comment Share on other sites More sharing options...
sunnyseven Posted January 13, 2016 Author Share Posted January 13, 2016 Oh, I see what's timing out, the time tracker. Must still be installing. Anyone know why it's so slow? Is it just a ton of information? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 13, 2016 Share Posted January 13, 2016 It depends on the speed of your Internet connection, but yes… mine took several hours as well. Actually, I left it running overnight. Link to comment Share on other sites More sharing options...
sunnyseven Posted January 13, 2016 Author Share Posted January 13, 2016 Thanks Michael. Looks like a few more hours to me. Just so long as it's not abnormal. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 13, 2016 Share Posted January 13, 2016 It's not unusual. It's a ton of data. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 13, 2016 Share Posted January 13, 2016 I did it in 2 min. Link to comment Share on other sites More sharing options...
Dermot Posted January 13, 2016 Share Posted January 13, 2016 The core libraries are fairly large (700 MB+) and can take a long time to download depending on your internet speed as well as traffic on our end. It is not possible to download the core libraries in only 2 minutes. If you have been an X8 beta tester and already had the libraries installed, then you would not need to reinstall them. For more information about downloading and updating libraries, please see the help topics in the program. To quickly find the help, just put your mouse over the menu item for Install Core Content or Update Library Catalogs and hit the F1 key. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 13, 2016 Share Posted January 13, 2016 Ok I must have updated the core, but it seems to have downloaded to whole thing. I update the lib's quite frequently . Link to comment Share on other sites More sharing options...
Dermot Posted January 13, 2016 Share Posted January 13, 2016 I believe updating the libraries should usually be much faster then the initial install. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 13, 2016 Share Posted January 13, 2016 I believe updating the libraries should usually be much faster then the initial install. This is definitely true for me. Original download of libraries typically takes several hours but updates are much faster. Link to comment Share on other sites More sharing options...
dshall Posted January 13, 2016 Share Posted January 13, 2016 .........Original download of libraries typically takes several hours but updates are much faster. Well Michael, if you did not live in the hinterland, it should take only 30 minutes....... it seems that when I download the core catalogs, the time is not an issue because I can still work with CA while downloading...... 30 minutes maybe? It is the bonus and manuf catalog downloads that is a big hassle..... for me anyway..... I am having a longing to visit Michael's great state of Alaska again...... it probably will not happen for a couple of years..... hey Michael, you know that whenever you come down into my neck of the woods, you are always welcome to give me a call so we can get together. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 13, 2016 Share Posted January 13, 2016 Well Michael, if you did not live in the hinterland, it should take only 30 minutes....... it seems that when I download the core catalogs, the time is not an issue because I can still work with CA while downloading...... 30 minutes maybe? It is the bonus and manuf catalog downloads that is a big hassle..... for me anyway..... I am having a longing to visit Michael's great state of Alaska again...... it probably will not happen for a couple of years..... hey Michael, you know that whenever you come down into my neck of the woods, you are always welcome to give me a call so we can get together. Thanks Scott. That is much appreciated : ) I'll have to let you know if we make it down that way again. You do the same if you head up this way. Link to comment Share on other sites More sharing options...
