dshall Posted December 12, 2015 Author Share Posted December 12, 2015 Another way... Get into Fillet Edit mode. Select the polyline or whatever you want to fillet. Get into the Fillet command by shortcut, menu, toolbar or whatever. At this stage you can use a hot key or the Set Fillet Radius icon on the Edit toolbar to set the fillet radius. Click exactly in the corner you want to fillet. http://screencast.com/t/m5ZUVcFyT1 I sent it into Brian Beck, this is his response... "Thanks Scott, I have logged this request in our database." Those guys up there don't show me any love.....soooooooooo.......tonight I am going to call Jessica Beck (Brian's Boss), I will have a word with her, she will then talk to Brian tomorrow morning over eggs and bacon, and Brian will have it fixed by Monday morning. Glenn, I get your method, I get the other methods, but a quick hot key, a tab, two inputs and I am done..... now that is easy peasy. Link to comment Share on other sites More sharing options...
glennw Posted December 12, 2015 Share Posted December 12, 2015 Scott, OK, I think this is as close as you can get with the existing tools. This is only a small variation to what you want in that you need to use Fillet edit mode. Get into Fillet edit mode - with a hotkey. Select the corner and drag along one of the lines - DO NOT DRAG INTO THE CENTRE. Tab. Enter the distance along the line. http://screencast.com/t/VAEgSHo5Kp 1 Link to comment Share on other sites More sharing options...
dshall Posted December 12, 2015 Author Share Posted December 12, 2015 Scott, OK, I think this is as close as you can get with the existing tools. This is only a small variation to what you want in that you need to use Fillet edit mode. Get into Fillet edit mode. Select the corner and drag along one of the lines - DO NOT DRAG INTO THE CENTRE. Tab. Enter the distance along the line. http://screencast.com/t/VAEgSHo5Kp Get the heck out of here! I'm on the iPad and can't see the vid, I will check it out in the am, if this works, it couldn't get any better, thx. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 12, 2015 Share Posted December 12, 2015 It works - Nice Glenn Link to comment Share on other sites More sharing options...
chief58 Posted December 12, 2015 Share Posted December 12, 2015 Good one Glenn that should work GREAT Link to comment Share on other sites More sharing options...
dshall Posted December 12, 2015 Author Share Posted December 12, 2015 Thanks Glenn, I spoke to Jessica who spoke to Brian and he fixed it post haste. Perfect, thank you. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 12, 2015 Share Posted December 12, 2015 Holding the 'F' key and dragging along the edge, instead of through the center of the arc works too - no need to change 'modes'.. Link to comment Share on other sites More sharing options...
