Garage With A Room Above
Clare_White
OK I have tried to figure this out on my own. I just can't figure it out. I am really bad about asking for help.
I have a three story house, basement, garage, and floors. I have everything pretty much correct except the garage with a room above. I need the room above the garage from the garage floor to the ceiling to be 104.5". See attached plan
I see where you have the garage marked on the lowest level but it has windows and do garage doors so I am not sure what you area trying to accomplish, I set the garage floor elevation to default in the garage which lowered the garage floor, is your garage in the basement or on level 1
You do not have a room defined above the garage.
I can not understand what you are trying to do from your description.
The room above the garage is not defined then you want to go from the garage floor to the ceiling? Garage Ceiling?
Or are you talking bout the room above the garage ceiling? Of which there is no room defined.
Andy.
