wingding5 Posted December 2, 2015 Share Posted December 2, 2015 So I have always sized my windows to the rough opening sizes and then just ordered them a little smaller. ie 3'x5' window would be framed 3'x5' and my supplier orders a 3'x5' RO (rough opening) thus when it arrives, it comes 1/2" smaller. 35 1/2"x59 1/2". That is all fine, but that does not work for making the window schedule look right. All that to be said: Is there a way to have your dimensions go to the RO size instead of the window?. I want my dimensions to be spot on for the framer not to where I exactly want the window. Probably something small that I have been missing all these years, but I have not found it yet. THANKS ANDREW CH v6-v17 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 2, 2015 Share Posted December 2, 2015 In the Window Schedule you can list the Size, Width, Height and the R/O. Typically Size is the item used for ordering which corresponds to Width & Height. The R/O is larger. Size: 2640DH ....2'6" wide, 4'0" tall, Double Hung Width: 30" Height: 48" R/O: 32"x50" (1" gap all around) the gap can be set in the Window dbx or in Defaults. Link to comment Share on other sites More sharing options...
johnny Posted December 2, 2015 Share Posted December 2, 2015 edit - Joe show's below there is a way. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 2, 2015 Share Posted December 2, 2015 You can set those locations in the Dimension Defaults (Locate Objects) Link to comment Share on other sites More sharing options...
Solution wingding5 Posted December 2, 2015 Author Solution Share Posted December 2, 2015 Yes. Joe you got it. I was able to go into dimension defaults and auto dimensions (locate objects). I think that is going to work. I knew there had to be a way. thanks andrew Link to comment Share on other sites More sharing options...
johnny Posted December 2, 2015 Share Posted December 2, 2015 Does someone mind verifying this works on their system. When I set the default to R/O its 1/2" off still. I couldn't get it to work, but maybe I am missing something. Link to comment Share on other sites More sharing options...
MoeGia Posted December 3, 2015 Share Posted December 3, 2015 Make sure your window is set up correctly. Open the window dialog, verify the correct size, then go to the framing tab and verify/change your framed opening size. You should be able to get the rough openings dimensioned correctly between the dimension settings (looks correct) and the window framing set up. Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted December 3, 2015 Share Posted December 3, 2015 The rough opening setting is for each side. If you want a 1/2" bigger RO make it 1/4". Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 3, 2015 Share Posted December 3, 2015 Does someone mind verifying this works on their system. When I set the default to R/O its 1/2" off still. I couldn't get it to work, but maybe I am missing something. Johnny, You need to uncheck "Sides". "Sides" picks up the side of the window itself, what you want is just the rough opening. Because you have both checked, auto exterior dimensions is using one of each. Link to comment Share on other sites More sharing options...
johnny Posted December 3, 2015 Share Posted December 3, 2015 Johnny, You need to uncheck "Sides". "Sides" picks up the side of the window itself, what you want is just the rough opening. Because you have both checked, auto exterior dimensions is using one of each. Yep that was it, thanks. I had thought it needed to be checked for the sides to be dimensioned, but works fine un-checked. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 3, 2015 Share Posted December 3, 2015 Chief tends to use Check Boxes in a lot of Dialogs where they should use Radio Buttons. If I was the boss there would be some GUI standards inforced. Check Boxes are intended for Multiple Choice Radio Buttons are intended for Exclusive. But Chief doesn't seem to have any consistency in how they use them. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 3, 2015 Share Posted December 3, 2015 Ya, in the case of auto dimensions, you're right. It should be radio buttons. I wonder if maybe they're just trying to keep dimension DBX's as consistent as possible...aside from auto dimensions, those should be checkboxes. Link to comment Share on other sites More sharing options...
