ebdesign Posted November 11, 2015 Share Posted November 11, 2015 I can't get the rake fascia to sq up no matter what settings I use in the roof spec dbx. This line shows up in layout & has to be cleaned up every time updated. Can anybody help me out please? Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 I wonder if it has something to do with your 1/16" gable sub fascia Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2015 Share Posted November 11, 2015 Jim, You need to send that plan to support. I don't think any of us are going to be able to help you. Actually, I'm not able to reproduce your issue. But I don't know all the settings for your roof - including the framing. Link to comment Share on other sites More sharing options...
ebdesign Posted November 11, 2015 Author Share Posted November 11, 2015 Thanks Scott. I've tried everything I can think off Scott. I've changed those settings numerous x's. Can you do it? For right now I'm just deleting the gable fascia surface before updating the elevations. There is not both a gable fascia & a gable sub fascia. & why is the gable fascia flat across like that? Link to comment Share on other sites More sharing options...
ebdesign Posted November 11, 2015 Author Share Posted November 11, 2015 Thanks for looking at it Joe. All my roof settings are in the images I attached. Options & Framing anyhow. Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 i now have what you have, I used a 1/16" x 1/16"gable end fascia. Change your gable end fascia size. Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 Sorry, I meant eave fascia size Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2015 Share Posted November 11, 2015 Jim, Uncheck "Eave Fascia". You may need to use a Molding PLine to add your own "Gable Fascia" since CA is using the CheckBox like a Radio Button. The do that in a lot of Dialogs - improper use IMO. Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 IOW, the gable end fascia will not be any lower than eave fascia..... if you want a deeper gable end fascia and still maintain a 1/16x1/16 eave fascia, use the GABLE END SUBFASCIA, in lieu of a GABLE END FASCIA.... I don't get it, but that is how it works. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 11, 2015 Share Posted November 11, 2015 Also that ridge should reduce, as not to show as in real life. This includes hips Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 11, 2015 Share Posted November 11, 2015 IOW, the gable end fascia will not be any lower than eave fascia..... if you want a deeper gable end fascia and still maintain a 1/16x1/16 eave fascia, use the GABLE END SUBFASCIA, in lieu of a GABLE END FASCIA.... I don't get it, but that is how it works.Yep that's what I do also Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2015 Share Posted November 11, 2015 Once you uncheck all the "Fascia's" you can add a Shadow Board to cover the edges of the Roof Sheathing. Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 Jim, Uncheck "Eave Fascia" yes Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2015 Share Posted November 11, 2015 Also that ridge should reduce, as not to show as in real life. This includes hips Yep, Link to comment Share on other sites More sharing options...
ebdesign Posted November 11, 2015 Author Share Posted November 11, 2015 Thanks a lot guys. Whatever works for now........ Perry, I'm not following. This is a copper standing seam roof w/ a raised metal ridge cap. Is it too tall you say? I appreciate the help. Link to comment Share on other sites More sharing options...
CAmichael240114 Posted November 11, 2015 Share Posted November 11, 2015 Adjusting the sub-fascia depth (eaves and Gable) controls the amount that the gable fascia will come down to give a plumb finish Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 11, 2015 Share Posted November 11, 2015 Thanks a lot guys. Whatever works for now........ Perry, I'm not following. This is a copper standing seam roof w/ a raised metal ridge cap. Is it too tall you say? I appreciate the help. No, I'm talking about the rafter and ridge/ hip framing as you can see in your pic. The ridge shows through the gable wall and you shouldn't see it below the rake or fascia boards, it should reduce like rafters do. This has been this way forever and we have put in many requests over the years. Link to comment Share on other sites More sharing options...
RayCas Posted November 11, 2015 Share Posted November 11, 2015 Hi Jim How about adding a shadow board same size as the rake, should cover up the rake with a sq. end, me thinks Ray C Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2015 Share Posted November 11, 2015 Ray, This has already been answered. Just uncheck all Fascia's. That will leave just the "Gable Sub Fascia" which is essentially the last Rafter. Then add a 5/8" x 1/2" Shadow Board to cover the edge of the Sheathing. It's that simple. Link to comment Share on other sites More sharing options...
ebdesign Posted November 12, 2015 Author Share Posted November 12, 2015 I gotcha now Perry. Thank you very much everybody. I had to get it out the door so it was a lot of edit layout work. But I am playing w/ all your suggestions now, Some of the issues: there is no "normal" fascia, shadowboard, or soffit anywhere; just the rake exposed rafter tails no full rafter to the defined overhang over the gable end walls a frieze tucked up under the roof sheeting sq cut tails 4x4 gutters that followed that rafter tail cut (can anybody get that auto?) 4 different roof slopes to deal w/ rafters were 2'oc from each rake edge w/ 2' standing seam roof pattern aligned w/ rafter tails 12"oc B&B wall siding also aligned under tails. On the elevations, there's only a couple inches of the tail seen below the gutter. Sounds like fun, eh? Hi RayC. Thanks for taking a look. Been a while since ......... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 12, 2015 Share Posted November 12, 2015 Jim, For the Gutter, create a Molding Profile at the correct angle. Assign that as the Gutter in the Roof Defaults. For some reason Chief didn't give us the ability to change the Gutter on an individual Roof Plan Basis. That object is just missing from the dbx. After changing the default gutter, just edit the roof plane and the new gutter will be applied. Link to comment Share on other sites More sharing options...
ebdesign Posted November 12, 2015 Author Share Posted November 12, 2015 Joe, I had to make 4 different sq gutter molding profiles, one for each slope, & individually assign horizontal & vertical offsets for each one. I ended up just doing it manually w/ molding plines assigned to the fascia elev & then offsetting for each slope. Fun, fun fun. Better way? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 12, 2015 Share Posted November 12, 2015 Joe, I had to make 4 different sq gutter molding profiles, one for each slope, & individually assign horizontal & vertical offsets for each one. I ended up just doing it manually w/ molding plines assigned to the fascia elev & then offsetting for each slope. Fun, fun fun. Better way? Probably not. Link to comment Share on other sites More sharing options...
RayCas Posted November 14, 2015 Share Posted November 14, 2015 I Hi RayC. Thanks for taking a look. Been a while since ......... Yes it has:-) semi retired still taking on a few jobs,,, Chiefs come a long way for sure.The other board gets very little activity, Eric still over there now and then causing trouble (joking) 1 Link to comment Share on other sites More sharing options...
