Designer100 Posted November 7, 2015 Share Posted November 7, 2015 Chief Architect x7, Cannot get post from going thru roof on 8' porch. Also the rear 14 ft porch gable up above is showing some of the baseline hanging down below ceiling. can anyone help me with these issues? I have only been doing ca for around 6 months. Link to comment Share on other sites More sharing options...
chief58 Posted November 7, 2015 Share Posted November 7, 2015 It would help if you posted the plan so we can see it Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 7, 2015 Share Posted November 7, 2015 sometimes it's as easy as hitting F12 to re-build. Link to comment Share on other sites More sharing options...
solver Posted November 7, 2015 Share Posted November 7, 2015 That front left post? I noticed it too yesterday. I'd start by deleting the 2nd floor and attic. That will fix several issues. Uncheck Balloon Through Ceiling Above (it's not needed) on the front and back walls, then rebuild the 2nd floor. If you don't want to loose that front gable, copy its parts, then Paste>Paste Hold Position to put them back. Delete railing on the ends of the porch, then using the Same Wall Type handle on the front railing, pull it around to the sides. Anyone know how fix the post in the image? It should go to the "ceiling". Post the plan for best ideas. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 7, 2015 Share Posted November 7, 2015 Try checking the box that railing wall to "Balloon thru ceiling". Link to comment Share on other sites More sharing options...
solver Posted November 8, 2015 Share Posted November 8, 2015 I tried Perry -- no change. Newell -- This roof, except for one minor fix is auto generated. Easy to set up on a simple roof like this. The real advantage is on the inside. Everything is clean and aligned. Link to comment Share on other sites More sharing options...
