Slab can not be selected
ACADuser
Just open the room DBX and uncheck floor under this room, and the slabs will go away.  You can select another type of room if you want the room to have different characteristics for the floor.  It seems redundant to have a landing and the porch room as well.
If you delete the "Walls, Railings" the slabs will go away.   They are the rooms floor.
Interesting that you cannot select the room in 3D view.
That is what I call the "virtual slab".  They are there because of the defined room.
