jlprojects Posted September 4, 2015 Share Posted September 4, 2015 Hi everyone, I need to add drawer's dimension to my cabinetry elevation. The NKBA dimensions don't give the drawers dimensions. Is there any easy way I can add these dimensions (without having to use the point to point dimension)? Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2015 Share Posted September 4, 2015 Are you talking about drawer openings, drawer boxes, drawer fronts, or...? Link to comment Share on other sites More sharing options...
Kbird1 Posted September 5, 2015 Share Posted September 5, 2015 Not sure I have seen that asked for before as usually the Drawer Box size is calculated depending on the Hardware (slide) used ,so is left to the cabinet Company to determine on their Shop Drawings. M. Link to comment Share on other sites More sharing options...
MarkMc Posted September 5, 2015 Share Posted September 5, 2015 Either make a CAD detailOradd a line open it, lock start I was mistaken, lock length/angle then set Y to zero (had gotten that from Scott Hall some time ago)Then using transform from view replicate offset copies to match the drawer heightYour dimensions will now snap to the lines. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 5, 2015 Share Posted September 5, 2015 Either make a CAD detail Or add a line open it, lock start I was mistaken, lock length/angle then set Y to zero (had gotten that from Scott Hall some time ago) Then using transform from view replicate offset copies to match the drawer height Your dimensions will now snap to the lines. Not that this won't work, but how is this different from using the point to point dimension tool and just changing the marker radius to zero? This is what I personally do whenever I have to use point to point. Link to comment Share on other sites More sharing options...
dshall Posted September 5, 2015 Share Posted September 5, 2015 Not that this won't work, but how is this different from using the point to point dimension tool and just changing the marker radius to zero? This is what I personally do whenever I have to use point to point. A quick comment, I do not like the point to point as much as creating the extra line. The point to point works, it's just that I think it is more difficult to edit and it seems like I have to edit everything in my life. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 5, 2015 Share Posted September 5, 2015 A quick comment, I do not like the point to point... Neither do I. Try to avoid it as much as possible. Link to comment Share on other sites More sharing options...
MarkMc Posted September 5, 2015 Share Posted September 5, 2015 For dimensioning cabinet faces the only options are points, lines, or cad detail (premier only). I just don't like how points behave, every now and then end up with points after editing something so dimensions don't reflect what's going on. I find it easier to notice something was edited with lines than with points. None are live so depends on the situation. If I have fussy face editing to do I use lines and make them longer than the cabinet. When it's time to send in an order I use detail from view..pick your poison. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 5, 2015 Share Posted September 5, 2015 ...I just don't like how points behave, every now and then end up with points after editing something so dimensions don't reflect what's going on. I find it easier to notice something was edited with lines than with points... This makes good solid sense. On a side note, not sure why I didn't notice it before now... Its not a perfect solution, but you can create an elevation flush with the cabinet face (essentially deleting the door and drawer fronts) and then set the backclip distance (essentially deleting shelves) for face frame/drawer box details. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 5, 2015 Share Posted September 5, 2015 This makes good solid sense. On a side note, not sure why I didn't notice it before now... Its not a perfect solution, but you can create an elevation flush with the cabinet face (essentially deleting the door and drawer fronts) and then set the backclip distance (essentially deleting shelves) for face frame/drawer box details. Nice Tip Michael , thx , had not thought of doing that either.... M. Link to comment Share on other sites More sharing options...
MarkMc Posted September 5, 2015 Share Posted September 5, 2015 Nice Michael-doesn't appear to work well for inset. To dimension that did you cad or lines? at least I still couldn't get dims on the rails. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 5, 2015 Share Posted September 5, 2015 I used end to end dimensions (which automatically insert points when snapping to cross section lines), and then just reduced the marker radii to zero...my standard practice for point markers. You're right though. Wouldn't work for inset doors or drawers. Link to comment Share on other sites More sharing options...
MarkMc Posted September 5, 2015 Share Posted September 5, 2015 Inserted points for me too, but to the drawer box, maybe my snap distance. I still don't want points but a much easier and safer way for me to get detail from view on overlay. Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 6, 2015 Share Posted September 6, 2015 Nice Michael-doesn't appear to work well for inset... Definitely not an ideal solution, but you can use a rectangular polyline or box with a fill to address this. This method has the added benefit of being fully dimension-able without the use of point to point. Link to comment Share on other sites More sharing options...
