Network server, sharing files?
Member Statistics
Similar Content
By LeeDrafter
Hello,
My "My Documents" folder on my work computer is actually on our server, and I know CA is not meant to be used over a network. I would like everything Chief Architect uses "My Documents" for to go in a different folder. How do I re-direct everything that references "My Documents"? I have started a folder on my hard drive called "CA My Documents" and was hoping to use that as the replacement folder. I have already moved all the CA files and libraries that I can find, but chief seems to look for that My documents folder sometimes.
Thank you,
Lee
X10
By YoderW
I work in an office setting with two coworkers, and we are trying to figure out a way to have one shared User Library. Our current setup has one computer hosting all of our project files, with each of our individual computers having remote access to the file directory. Our computers have Chief set up individually, with our own libraries and data directories currently. Our primary desire is to share the libraries we've each created for materials and color swatches, as well as custom models. We do work for 40-50 facilities, and they like to change up their materials and colors relatively often, so keeping all of it coordinated and organized can be difficult.
Our desire is to have a shared User Library on the host computer that we all have access to, that will update itself without us having to constantly export and import the libraries for each other. Kind of like how Chief will automatically check for updates to the library catalogs you can download from the website. This way if one of us creates new items in our own library, it will update for everyone.
I've searched Google and the forums multiple times over the last couple days and have found that it should be possible, but the "solutions" are either for a much older version of Chief, the people involved don't describe how they set it up, or they use an extra 3rd-party application to help. Our company is extremely strict about what we install on our machines, so we can't guarantee they would approve a small program we download from what they may consider to be a questionable site. The specific solution i'm thinking of was set up for OneDrive, too, so i'm not sure it would even work for us. OneDrive is a potential option, but again, we'd like to avoid the extra programs involved in that solution. Surely there should be a way to set this up with Chief alone by now? I tried creating a folder on our shared drive and redirecting my own User Library there, but it didn't update itself when I scanned after having a coworker make a change to one of the libraries I had created and re-export it to said folder.
Thanks in advance!
By glipovsek
Chief architect works great on my work computer and my home laptop. However, when I VPN from my home laptop to my work computer, Chief freezes on the start up screen. We work all of our chief files from a server at the office. I can access and work on anything else from the server, but chief always freezes up immediately. What can fix this? Faster internet upload/download speeds? Something else? THANKS in advance!
By Garreth
Hi All just wondering if anyone is experiencing the same issue with Chief as we are.
Is Chief Architect going to consider developing a networkable , multi user format for those of us who have more than two employees and endeavouring to manage large projects over various disciplines..
Our office works on medium to large commercial projects where files are constantly being modified and worked on 6 months or more in duration and on various elements of the same model.
Because the files are linked between details , wet area layouts elevations and floor plan etc etc, our productivity is limited to one user on the file at any one time.
thanks in advance
Garreth
By ericepv
I have occasionally gotten requests from clients for a reader program so they can tour a plan on thier own. While I am famillar with the Chief Reader download that is available, it would require me to provide a full copy of my Plan File which as a general rule I never do. I know that one cannot print, edit or save with this reader but the possibility remains that my file could end up in the hands of another Chief user (a competitor?) which is why I nver give out my Plan File.
I asked Chief tech support if it is possible to create a read oniy version of the file and I was told that while this once was the case, that option is no longer available. Does anyone know of a workaround to this problem? (I am currently on X7)
