Layback Posted August 27, 2015 Share Posted August 27, 2015 Temporary dimensions in X7 display in dark gray by default and are hard to read. Been using CA for 10 years or so and for the life of me can't figure out how to change the color of temporary dimensions in X7. A solution would be appreciated Link to comment Share on other sites More sharing options...
MPDesign Posted August 27, 2015 Share Posted August 27, 2015 Preferences, appearance, colors 2 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 27, 2015 Share Posted August 27, 2015 Never knew that. Apparently it's 'selection line color'. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2015 Share Posted August 27, 2015 Never knew that. Apparently it's 'selection line color'. Thx Michael ,good tip , I thought I was stuck with grey too , I guess it's there somewhere in the 1400 page manual but who would think " selection line" was the right setting for that ? Strange it isn't in with the other Dim. Settings. Link to comment Share on other sites More sharing options...
Ikedcr Posted August 28, 2015 Share Posted August 28, 2015 I never knew that. Great tip. Thank You. Ike Link to comment Share on other sites More sharing options...
SeasideHome Posted September 30, 2015 Share Posted September 30, 2015 Similar issue, thought this might answer my question, but no - When placing temporary dimensions in CA 7, the dimension is positively illegible until the point is accepted and positioned.It looks as it the dimension font (green here @ bottom) is super heavy line weight, even if the dimension defailt is line weight "1".Can someone assist? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 3, 2015 Share Posted October 3, 2015 It almost looks like you are using the wrong annotation scale ( too large?) Seaside and it is blocking into those green blobs.... Link to comment Share on other sites More sharing options...
