etefonori
Purchase individual product catalogs
I'm currently using Home Designer suite 2015 and I need the KraftMaid catalog.
I can't afford to upgrade to the Pro version and there's no SSA for the Home versions.
Is there any way to purchase just individual catalogs?
nope, sorry
you could try calling CA's customer service to discuss
BTW:  this forum is for mainly for users of Chier Premier
HD product users would find little benefit following this forum
except for HD PRO users
check out the HD Hometalk forum which is focused on HD products
Lew
Lew,
I posted here because the catalog I'm looking for is only available to the PRO users with SSA.
Tanya
Individual purchasing of Libraries for various products is something we want to implement.
Unfortunately, we currently don't offer them except throught the SSA program on our Proffesional Product lines.
As an option, there is a rent to own program available:
http://www.chiefarchitect.com/products/premier/
You would have access to the libraries while renting.
Tanya:
got it
for some reason CA doesn't make it clear about the two forums
and many HD users end up at Chietalk  causing confusion and frustration for all
Lew
Not sure if you realize that the only items in the Kraftmaid catalog are Doors and drawers, Finishes, and wood species.
FWIW none of the brands I use have catalogs in Chief. I set a default template to have the correct toe, top drawer hieght and overlay. I also make a folder in my user catalog where I add cabinets as I modify or build them for each mfg. I used to collect doors from whatever manufacturer catalog had something close but now I make them.
I think you can do all of those things in HD? IF you can't make doors in HD you can in Sketchup and then import them.
I don't know if HD opens chief files but if it does I've posted a couple of Plan files that are door kits. They can be used as a starting point to make door symbols or as a guide to one method of doing that.
HD can open and edit Chief plans if the "edit flag is set"
Lew
Lou, is that something I'd do on this end? If so I'll figure it out and repost the plan
Yes Mark ,   it is a setting in the Defaults>Plan.... about 3rd option down ? near "ignore casing on resize" I actually have it set in my template plan just incase.
Here is a door kit plan that can be used in HD products. I'm not sure which of these procedures work in the Suite version, hope enough so you can use them. IF it doesn't allow converting to a symbol then these won't do you much good since the only 3D export Suite offers is dxf which it won't import. In that case you'll be better off in Sketchup which a lot of folks use to create door symbols.
I included: a couple of door kits not yet made into symbols, a few molding profiles, a couple of cameras I use to check (I think these only work in Pro version though) and adjust the molding placement (I think these only work in Pro version so getting the 3D molding line properly placed will be a challenge), and a couple of doors symbols so you can check the sizing tab to see how to set the stretch planes.
Save it as a template. Open it, pick a door to work on, delete all the others, save as, change moldings and panel if need be, delete the wall and cameras, take a 3d view and convert to symbol.
Door kit assortment.zip
Can you use the symbols from 3D Ware house in Premier??
Not all symbols are well made but as a general rule yes in .skp or .dae file types , using the import menu or drag and drop in the CA Window.
IF you drag & drop it will automatically be a fixture.  Use the import process to set name, type of item (electrical, fixture, etc.) and sometimes adjust the offsets for the 2D cad  block.
I usually use D&D to test an object from 3DWH , as it doesn't add it to the library etc , then I just delete it if textures , size etc are messed up ,especially these day when a lot of objects don't have real textures , instead they have a pic laid on the surface of the block CA doesn't handle these well.
I usually then do the full import , if I plan to keep and reuse it ,  but didn't realise  if you D&D'd it was auto a Fixture
    27469
    THDesign
    THDesign
