Denco2015
Deck Floor/planking
when I design a deck room it does not allow me to change the material for the decking. It installs an interior flooring instead of planking and does not let me change it through the room details. How can I fix this?
Open the dialog box of the deck (I assume you named the room "Deck"), then on the Structure Tab - Floor Structure - Floor Finish set to "zero" inches and just below is "planks-joists" where you can alter the surface material of the deck planks.
or just call it a balcony. depending on what you need
Set you Deck Room Defaults as you need them using DJP advice ,so every deck you draw is the same ....
Edit>defaults>Rooms>Deck Room>Structure Tab
Decks should not have a Floor finish , make it 0"
    27478
    Oilersfan20
    Oilersfan20
