Bay/Bow windows
kirbywhitetail
I assume you are speaking of the box-bay window tool, it has its limitations for sure but if you will read the reference Manual section on the use of that tool should answer any left over questions. Generally, I prefer to draw such things manually, it is a little more trouble but gives one greater control.
The Reference Manual can be found under the "Help" menu-Reference Manual. That is your "Go-To" document when you need detailed help.
