Sign in to follow this
Julies
I've Lost The 'parent And Child' Toolbards
Help!  When using the programme earlier today I had three menu bars along the top of the screen - now I only have one, and I would like to know how to reinstate the others.
Can anyone help with this please?
Julie
You fix that sort of thing by going to "Tools -Toolbars and Hot Keys-Customize" which offers you a dialog where to the "Configurations Tab" select "Default Configuration" and then "Switch to" to return things to "normal"
Thank you for the reply - however I still cannot sort this.  I cant find the "switch to" instead I found restore to previous version - but as I don't have a previous version it wont work!
Im using Home Designer Suite 2016 by the way.....
this forum is for Chief Premier
HD Suite is a very limited sub-set of Chief Premier
you should check out the Hometalk forum which better serves the HD product line
Lew
Switch to    is on the Configuration Tab if you have it ?
if not there, try Edit >Preferences>Reset Options>Reset Side Windows    hit ok and restart the Program
HomeTalk is over here BTW ..same User ID and Password
https://hometalk.chiefarchitect.com/index.php?/forum/5-qa/
Or you could try View...Toolbars
    27469
    THDesign
    THDesign
