Black Spot Printing On My Elevations
DBCC-pinky
Go to solution Solved by Athenian_CAD,
When I went to print elevations from a layout the print comes out black. The elevations appear fine in the layout window, but when I print it turns the elevation black and further investigations makes it appear as though it is a black spot over the elevation, but only when printed.
Any suggestions would be helpful.
test.pdf
I see a huge dark gray "fill" covering your elevation in the PDF you attached.  I see it in my PDF reader/editor before even trying to print anything. It looks like perhaps you have something in your layout causing the problem.  Maybe something on page zero?  Can you attach the plan and layout that you're using?
Athenian CAD- you may be on to something.... the line wieght button does effect the appearance. It seems to appear only in the section view set.
Thank you... I was able to pinpoint the problem to the linewieght of the material for the walls. Great advice thank you again
