StudConstruction Posted May 19, 2015 Share Posted May 19, 2015 I'd like to be able to create a single elevation callout in the center of the room as is shown in the attached image. Is there a way to do this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 19, 2015 Share Posted May 19, 2015 You should post this in the Q&A or Suggestions Forum. Then delete it from this Forum because it isn't a Tip, it's a Question. Link to comment Share on other sites More sharing options...
jbaehmer Posted May 19, 2015 Share Posted May 19, 2015 Place a standard Callout and in the DBX box, change the number of arrows to 4. you will still need to place text at each arrow, but then you can make it a CAD block and save in your library. What the heck...I will just do it for you! Untitled 1.plan 1 Link to comment Share on other sites More sharing options...
StudConstruction Posted May 19, 2015 Author Share Posted May 19, 2015 Place a standard Callout and in the DBX box, change the number of arrows to 4. you will still need to place text at each arrow, but then you can make it a CAD block and save in your library. What the heck...I will just do it for you! Thanks! I appreciate the help despite my inaccurate topic placement. Link to comment Share on other sites More sharing options...
tommy1 Posted May 20, 2015 Share Posted May 20, 2015 Look in the library for room call-outs. They have the look you want. Link to comment Share on other sites More sharing options...
tommy1 Posted May 20, 2015 Share Posted May 20, 2015 BTW, it comes with Chief and is already in the library. Here it is explained better. Unblock it. Edit it. Re-block it. Looks like yours. Link to comment Share on other sites More sharing options...
ZacUriah Posted August 27, 2024 Share Posted August 27, 2024 Okay but I am only able to link one elevation to it not all four. Link to comment Share on other sites More sharing options...
