decorators3 Posted September 9 Share Posted September 9 I received a ZIP file from a developer that was originally sent by another draftsman. Can anyone tell me how I can determine how many floor plans, if any, are included in the file? When I opened the ZIP, I found a floor plan layout , but when I open it in Chief only see dwg files I’m not sure if I’m missing something, if there are other files I should be opening, or if only one floor was actually included. Any help would be appreciated! Lot 13.zip Link to comment Share on other sites More sharing options...
Doug_N Posted September 9 Share Posted September 9 The zip file contains AutoCAD files only, and when opened in AutoCAD, there are two floor plans: a basement and a main floor. You will need to import the dwg file that has the floor plans. Your first step should be to unzip the files to a new directory and then open them in AutoCAD to find the files that you need for CA. Link to comment Share on other sites More sharing options...
decorators3 Posted September 9 Author Share Posted September 9 I have only chief.. no auto cad Link to comment Share on other sites More sharing options...
JKEdmo Posted September 9 Share Posted September 9 40 minutes ago, decorators3 said: I have only chief.. no auto cad Autodesk has a free DWG viewer that allows you to view Acad files: https://www.autodesk.com/products/dwg-trueview/overview Link to comment Share on other sites More sharing options...
BenPalmer Posted September 9 Share Posted September 9 In addition to what the others said....you can import the CAD file into Chief....for viewing, manipulation, etc. 1 Link to comment Share on other sites More sharing options...
decorators3 Posted September 11 Author Share Posted September 11 thank you everyone for your responses.. greatly appreciated Link to comment Share on other sites More sharing options...
