ChristianA Posted June 23 Share Posted June 23 I have a situation where I want the corner post of the rail wall to extend all the way to the corner. I have everything, and the solid wall always goes to the corner and the first post of the rail sits next to it. Am I missing something here? Thanks in advance. Christian 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23 Share Posted June 23 Maybe there will be a solution for these issues in X18. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 23 Share Posted June 23 22 minutes ago, ChristianA said: Am I missing something here? I tried messing with room dividers to at least get the condition in plan view but as you can see in 3D it doesn't match the plan. Link to comment Share on other sites More sharing options...
JonathanK Posted June 23 Share Posted June 23 So you can actually drag the newel post over to be in front, but CA does NOT like it. It immediately just makes it a half post (regardless of your post style you select), and there is a lot of funkiness in how it builds in 3D. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23 Share Posted June 23 1 hour ago, Michael_Gia said: room dividers to at least get the condition in plan view but as you can see in 3D it doesn't match the plan That's not actually the correct view in the plan. What appears to be a newel post is actually a part of the wall but without the fill. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 23 Share Posted June 23 Fairly easy solution: 260623.mp4 3 Link to comment Share on other sites More sharing options...
ChristianA Posted June 23 Author Share Posted June 23 Hi Rene, Thanks for the vid. I was super hopeful after watching. I tried your method on my file and as soon as I move the room divider up to the edge of the post, the solid wall goes right back to the corner. Does it make a difference that the rail wall and solid walls make up the room? Here's the plan file for reference Christian Unit 9.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 23 Share Posted June 23 260623 (3).mp4 2 Link to comment Share on other sites More sharing options...
ChristianA Posted June 23 Author Share Posted June 23 As I like to say, "dude!!" Worked like a charm after watching your second video. Appreciated! How the hell did you figure that trick out? Christian Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 23 Share Posted June 23 4 hours ago, Joe_Carrick said: What appears to be a newel post is actually a part of the wall but without the fill You are correct. But it was a hopeful illusion for a moment. Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 23 Share Posted June 23 René is on another level. 1 1 Link to comment Share on other sites More sharing options...
