SHCanada2 Posted Thursday at 02:30 AM Share Posted Thursday at 02:30 AM seems to happen on residential template as well. only happens in section views. plan views are fine. auto build framing is off Anyone else seen this? its pianfull when trying to move something to a specific spot, because you have top move the mouse and then wait for CA to catch up Its been happening for awhile. I updated my video driver a couple days ago, but its no better see attached ' Screen Recording 2026-05-27 203604.mp4 Link to comment Share on other sites More sharing options...
ValleyGuy Posted Thursday at 02:42 AM Share Posted Thursday at 02:42 AM 10 minutes ago, SHCanada2 said: seems to happen on residential template as well. only happens in section views. plan views are fine. auto build framing is off Anyone else seen this? its pianfull when trying to move something to a specific spot, because you have top move the mouse and then wait for CA to catch up Its been happening for awhile. I updated my video driver a couple days ago, but its no better see attached ' Screen Recording 2026-05-27 203604.mp4 11.01 MB · 0 downloads I also experienced this. I did a complete shut down and rebooted my Mac and it seemed to clear up the glitch. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 03:25 AM Share Posted Thursday at 03:25 AM I'm not seeing this problem. What rendering mode are you using? What LayerSet? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Thursday at 03:42 PM Author Share Posted Thursday at 03:42 PM (edited) 12 hours ago, Joe_Carrick said: What rendering mode are you using? What LayerSet? i just drew 4 walls on the stock residential template, then a back clipped cross section, so the stock layerset assocaited with that. But I did try before that, on my own plan switching to the all layers off layerset, so nothing was showing, and it was still happening. But the plan view is always fine 13 hours ago, ValleyGuy said: I did a complete shut down and rebooted my Mac and it seemed to clear up the glitch. how often are you rebooting? I get windows crashes on a regular basis when I have PBR opened (never used to before say 5 months ago), so for this reason the computer is getting rebooted on a fairly regular basis. but I will try and do a clean reboot to see if it changes anything Edited Thursday at 03:44 PM by SHCanada2 Link to comment Share on other sites More sharing options...
ValleyGuy Posted Thursday at 04:43 PM Share Posted Thursday at 04:43 PM 42 minutes ago, SHCanada2 said: i just drew 4 walls on the stock residential template, then a back clipped cross section, so the stock layerset assocaited with that. But I did try before that, on my own plan switching to the all layers off layerset, so nothing was showing, and it was still happening. But the plan view is always fine how often are you rebooting? I get windows crashes on a regular basis when I have PBR opened (never used to before say 5 months ago), so for this reason the computer is getting rebooted on a fairly regular basis. but I will try and do a clean reboot to see if it changes anything It only happened once and I am not quite sure what triggered it. I don't use PBR, ...well I do click on it once every year or so - I'm not sure if I hit the button the day that I had the lag issue or not. The only computer crashes I have are if I leave CA open (no plan or layout open) too long without using the program. Example: if I close down the plan but don't exit the program overnight, then in the morning I will see where my computer rebooted itself with a 'Kernel Panicked' reboot report. But no crashes while I'm using the program. On a separate note, I just had an error the other day to which I followed CA protocol and sent in a bunch of information. It too was on a cross section elevation; just updating a view port on the layout. CA Helpdesk couldn't find or replicate any issues and I haven't had any issues since. Both the lag issue and the error code seem to be one-offs. I only loaded up X17 a couple of months ago but have had two strange things happen as well as a few Kernel reboots. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 06:17 PM Share Posted Thursday at 06:17 PM Evidently this only happens on a Mac - and then only under certain conditions. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Thursday at 06:56 PM Author Share Posted Thursday at 06:56 PM 37 minutes ago, Joe_Carrick said: Evidently this only happens on a Mac - and then only under certain conditions. well maybe if it happened in 1988 when I last used a mac ... Link to comment Share on other sites More sharing options...
SHCanada2 Posted Thursday at 09:54 PM Author Share Posted Thursday at 09:54 PM (edited) i rebooted, same issue. Tried to see if it happend on X16, and got this error when just starting X16 without opening anything going to try and roll back the driver Edited Thursday at 09:55 PM by SHCanada2 Link to comment Share on other sites More sharing options...
ChiefTylerL Posted Thursday at 10:03 PM Share Posted Thursday at 10:03 PM Does changing your Synchronize with Cursor Preference change this behavior at all for you? This setting can be found by going to Edit> Preferences and going to the Edit panel on the left side. Here you will find a setting for Synchronize with Cursor. If this doesn't make any kind of change I would try a different mouse, if you have one on hand. If you're still experiencing the problem I would recommend contacting Technical Support through the Technical Support Center: https://www.chiefarchitect.com/support/article/KB-00717/using-the-technical-support-center.html Link to comment Share on other sites More sharing options...
SHCanada2 Posted yesterday at 05:07 AM Author Share Posted yesterday at 05:07 AM 7 hours ago, ChiefTylerL said: Does changing your Synchronize with Cursor Preference change this behavior at all for you? that seems to mask the problem. Now when I move the mouse there is a delay in the mouse pointer moving (which is now tied to the crosshairs) I tried 3 different mice, same problem. Not to mention the problem does not occur in plan view. Link to comment Share on other sites More sharing options...
ValleyGuy Posted 23 hours ago Share Posted 23 hours ago 4 hours ago, SHCanada2 said: I tried 3 different mice, same problem. Not to mention the problem does not occur in plan view. .... you may have jinxed me lol. Last nite and now again this morning I have a second weird thing happening with a different cross section. I'm not sure if it has anything connected to your mouse delay, but it is only happening in x-section - not in plan view. Cross Section Jump.mp4 Link to comment Share on other sites More sharing options...
ValleyGuy Posted 21 hours ago Share Posted 21 hours ago ....Ok, my flicker issue is purely self-inflicted ... my cross section was on Update Always instead of Update on Demand. Oooops Link to comment Share on other sites More sharing options...
