ameyarchitect Posted April 22, 2015 Share Posted April 22, 2015 I am working on a project in X7 and the rendering is having inconsistencies with the texture of the siding. if you look near the door on the left side you can see where the siding appears flat instead of like a lap siding. Any thoughts? Christina Amey Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted April 22, 2015 Share Posted April 22, 2015 That's weird. It looks like it is occurring in regions directly above a cast shadow. There is also a patch of siding flattened just above the shadow of the high portion of the wood screen and the one around the door opening appears related to the shadow cast by the lower portion of the wood screen and there is also the second floor window above the entrance door where the shadow has completely obscured a the lower portion of the window. Have you tried changing the sun angle to see if it has an effect? Graham Link to comment Share on other sites More sharing options...
Gawdzira Posted April 22, 2015 Share Posted April 22, 2015 My thought is that you should post the plan. It could be a wall layers issue. It could be the sun (lighting). It could be your video card. Is Saturn in retrograde? Link to comment Share on other sites More sharing options...
Kbird1 Posted April 22, 2015 Share Posted April 22, 2015 Plan would help ,as we could see if it happens on our systems too , I suspect a videocard issue...laptop with Intel HD perhaps? Link to comment Share on other sites More sharing options...
jcaffee Posted April 22, 2015 Share Posted April 22, 2015 Post the plan, but also try ray tracing with the siding bump mapped. jon Link to comment Share on other sites More sharing options...
