jjifmeyer Posted Friday at 09:18 PM Share Posted Friday at 09:18 PM Trying to make a sign on a pole. I know I'm close but I cant figure out how to align and attach the two primitives to complete the task. I need to rotate, align and attach the cylinder primitive (sign pole) to the polyline solid (sign face). I just cant figure this out. cant figure how to get the cylinder in the correct position in 2d view. Hope this makes sense. Link to comment Share on other sites More sharing options...
ericepv Posted Friday at 09:48 PM Share Posted Friday at 09:48 PM You don't need to attach them, just select both items and create an Architectural Block. You could also convert it to a symbol or just find one to download from 3D Warehouse. https://www.chiefarchitect.com/support/article/KB-00809/converting-an-object-into-a-symbol.html https://www.chiefarchitect.com/support/category/186/architectural-blocks.html Hope this helps - Eric Link to comment Share on other sites More sharing options...
jjifmeyer Posted Friday at 09:58 PM Author Share Posted Friday at 09:58 PM not sure how to rotate the cylinder in 2d view? Thanks Link to comment Share on other sites More sharing options...
Mark3D Posted Friday at 10:37 PM Share Posted Friday at 10:37 PM Steps to rotate Link to comment Share on other sites More sharing options...
ericepv Posted Friday at 10:51 PM Share Posted Friday at 10:51 PM (edited) One more method - right click, choose 'transform/rotate'. Edited Friday at 10:53 PM by ericepv Typo Link to comment Share on other sites More sharing options...
johnny Posted yesterday at 01:42 AM Share Posted yesterday at 01:42 AM (edited) 4 hours ago, jjifmeyer said: Trying to make a sign on a pole. I know I'm close but I cant figure out how to align and attach the two primitives to complete the task. I need to rotate, align and attach the cylinder primitive (sign pole) to the polyline solid (sign face). I just cant figure this out. cant figure how to get the cylinder in the correct position in 2d view. Hope this makes sense. Yes, it’s useful to know how to rotate a cylinder in Chief....and honestly, the program could handle 3D rotation more intuitively. That said, after reading your post a couple of times, I’m not sure why you’d need to rotate the cylinder in this case. When it’s brought into Chief, it’s already oriented vertically along the Z-axis. Assuming your goal is to keep the pole vertical, the better approach is to draw the polyline solid in a 2D elevation view facing the pole. The issue here isn’t with the cylinder itself, but with the perspective you’re working in. Right now, you’re viewing the model from a top-down (plan) view, so you’re only seeing the top of the pole. In other words, the pole is already positioned correctly....you’re just looking at it from the wrong angle to then draw the sign part. Again, i'm presuming its a traditional sign-like condition where the sign orientation (front) is being "held" by a vertical pole. If thats not the case, then i'm not sure what you're trying to do. Edited yesterday at 01:54 AM by johnny 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted yesterday at 11:01 AM Share Posted yesterday at 11:01 AM In elevation view you can also rotate objects on the z-axis. Link to comment Share on other sites More sharing options...
jjifmeyer Posted yesterday at 02:56 PM Author Share Posted yesterday at 02:56 PM Yes to all, thanks for the help. I just wasn't thinking correct yesterday. It has been a while since I've worked with CA. Link to comment Share on other sites More sharing options...
