ArchStudent Posted April 17, 2015 Share Posted April 17, 2015 I'm in an architecture class and we are trying to find out how to find the height of a wall so we know what height to use when building a model of as house plan. Can anyone help me? Link to comment Share on other sites More sharing options...
Gawdzira Posted April 17, 2015 Share Posted April 17, 2015 Use a section view elevation camera and measure the result. Link to comment Share on other sites More sharing options...
rlackore Posted April 17, 2015 Share Posted April 17, 2015 See Alan's answer, or open the room dialog box and check the structure tab. Link to comment Share on other sites More sharing options...
ArchStudent Posted April 17, 2015 Author Share Posted April 17, 2015 What about if you want to see it without the siding, as just the framing? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 17, 2015 Share Posted April 17, 2015 Ceiling height is usually the wall height within Chief. Use the perspective framing overview camera for a framing shot. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 17, 2015 Share Posted April 17, 2015 If you have built the framing for the wall, the framing will show when you cut the section. Link to comment Share on other sites More sharing options...
Solution CJSpud Posted April 17, 2015 Solution Share Posted April 17, 2015 If you are interested in seeing wall framing for individual walls, just select the wall and then in the edit tool bar, click on the tool I have circled: Using the dimension tools, you can check the rough framing dimensions for any framed wall section: Link to comment Share on other sites More sharing options...
