John_B Posted yesterday at 12:51 AM Share Posted yesterday at 12:51 AM Would like to build corbel at eave soffit per enclosed pic. I've created the corbel but it would add when I try to add as a rafter tail molding it won't...I know I can just add them at 24" oc manaully but I need to get rid of the facia and when I do that the front Gables come out chopped...suggestions? Link to comment Share on other sites More sharing options...
joey_martin Posted yesterday at 01:04 AM Share Posted yesterday at 01:04 AM Remove fascia and sub-fascia and add these as rafter tails. Link to comment Share on other sites More sharing options...
John_B Posted yesterday at 02:10 AM Author Share Posted yesterday at 02:10 AM 1 hour ago, joey_martin said: Remove fascia and sub-fascia and add these as rafter tails. Tried that before posting, here's what I got.. Link to comment Share on other sites More sharing options...
mtldesigns Posted yesterday at 02:41 AM Share Posted yesterday at 02:41 AM @John_B Are all your roof layers on? You shouldn't be seeing OSB. How far out is your over hangs, this render looks almost flush.? Link to comment Share on other sites More sharing options...
John_B Posted 13 hours ago Author Share Posted 13 hours ago (edited) 11 hours ago, mtldesigns said: @John_B Are all your roof layers on? You shouldn't be seeing OSB. How far out is your over hangs, this render looks almost flush.? Yes, all layers with 8" at eaves, 4" at gable Edited 13 hours ago by John_B Link to comment Share on other sites More sharing options...
John_B Posted 13 hours ago Author Share Posted 13 hours ago 12 hours ago, mtldesigns said: @John_B Are all your roof layers on? You shouldn't be seeing OSB. How far out is your over hangs, this render looks almost flush.? The OSB you're seeing is from under the roof because the blocking is not there for some reason, here a it is with all framing layers turned on showing the rafter tails sticking out 15" whjich I did not specifiy as you can see above! Link to comment Share on other sites More sharing options...
MPDesign Posted 13 hours ago Share Posted 13 hours ago Have you rebuilt the roof framing after adding the profile? Link to comment Share on other sites More sharing options...
