How do I simply create these corbel extensions and not have the large Eave Fascia?
John_B
Would like to build corbel at eave soffit per enclosed pic.  I've created the corbel but it would add when I try to add as a rafter tail molding it won't...I know I can just add them at 24" oc manaully but I need to get rid of the facia and when I do that the front Gables come out chopped...suggestions?
Posted (edited)
11 hours ago, mtldesigns said:
@John_B
Are all your roof layers on?  You shouldn't be seeing OSB.  How far out is your over hangs, this render looks almost flush.?
Yes, all layers with 8" at eaves, 4" at gable
Edited by John_B
12 hours ago, mtldesigns said:
@John_B
The OSB you're seeing is from under the roof because the blocking is not there for some reason, here a it is with all framing layers turned on showing the rafter tails sticking out 15" whjich I did not specifiy as you can see above!
