GeneDavis Posted 7 hours ago Share Posted 7 hours ago (edited) Two pics attached. I want each side to have its railing die into the wall, meaning that the stair widens one side at a different tread than the other. I also want the newels moved enough out, out meaning away from the bottom riser and tread nose, so that both tread and riser resolve into the newels. Steve from Chief Skills has a six-year-old video up on YouTube and he hacks it by pasting on short 3" and 2" wide stairs at the bottom runout. But that was a few Xs ago. This need of mine has gotta be a common one. How do you address it in X17. South Park Charleston.7z Edited 6 hours ago by GeneDavis Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago I think all you need to do is add a "complete break" to your stair where the wall ends and then you can make the lower section wider. I did a quick look but could not find a tech article or video on it although I thought for sure there was one. Link to comment Share on other sites More sharing options...
