ChiefUserKatie Posted February 3 Share Posted February 3 Is there a way to easily reorder elevations? We do a lot of whole-home remodels, which means we end up with elevations in nearly every room. I try to organize them correctly from the start, but realistically I don’t always get them in the right order. Sometimes I forget to add an elevation until later, and then I want to reorganize them so the plan set flows better. When you have 20–30+ elevations, it becomes pretty tedious to go into each one and manually rename or renumber them. Is there a way to automatically sort elevations? Ideally, I’m imagining a feature where all elevations could be shown in a list and you could drag and drop them into the desired order, with the elevation names or numbers automatically updating based on that order. Thanks in advance for the help! Link to comment Share on other sites More sharing options...
basketballman Posted February 3 Share Posted February 3 P. M. sent .. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 3 Share Posted February 3 are you referring to changing their location in layout, or just renumbering/naming? Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted February 9 Author Share Posted February 9 @SHCanada2 Just referring to renumbering/naming Link to comment Share on other sites More sharing options...
mtldesigns Posted February 9 Share Posted February 9 On 2/3/2026 at 2:28 PM, ChiefUserKatie said: When you have 20–30+ elevations WOW! Do you do a elevation of every wall in the home, no matter if its a blank wall just with a few outlets? I'm curious for sure. Not sure 100% I understand your question besides just simply renaming in your tree. Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 10 Share Posted February 10 (edited) Rename them from the project browser. Also, let me suggest a change... Switch to a callout "rose" which is a callout with 4 "arrows" and no number used. Then label your elevations left right rear front. So your elevations show up as laundry right, laundry left, and you have a single callout indicating that there are 4 laundry room elevations on page A-5 such that your callout shows LE/A5. You'll never have to worry about numbering them again Edited February 10 by Renerabbitt Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted Thursday at 09:04 PM Author Share Posted Thursday at 09:04 PM On 2/9/2026 at 5:59 PM, mtldesigns said: WOW! Do you do a elevation of every wall in the home, no matter if its a blank wall just with a few outlets? I'm curious for sure. Not sure 100% I understand your question besides just simply renaming in your tree. Not every wall of the home, but a good number of them! If it has cabinets / tile / wood paneling / etc. ; it can add up on multi-space projects with a lot of detail. Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted Thursday at 09:07 PM Author Share Posted Thursday at 09:07 PM On 2/10/2026 at 5:30 AM, Renerabbitt said: Rename them from the project browser. Also, let me suggest a change... Switch to a callout "rose" which is a callout with 4 "arrows" and no number used. Then label your elevations left right rear front. So your elevations show up as laundry right, laundry left, and you have a single callout indicating that there are 4 laundry room elevations on page A-5 such that your callout shows LE/A5. You'll never have to worry about numbering them again Agreed; I think project browser is the best way to go for now. I like the rose idea. Do you paste a CAD block rose and hide the single elevation callouts that chief generates? Or is there a way that they are linked somehow Link to comment Share on other sites More sharing options...
Renerabbitt Posted Friday at 10:05 AM Share Posted Friday at 10:05 AM 12 hours ago, ChiefUserKatie said: Agreed; I think project browser is the best way to go for now. I like the rose idea. Do you paste a CAD block rose and hide the single elevation callouts that chief generates? Or is there a way that they are linked somehow The callout tool can produce a callout that can link to an elevation camera and post its reference information such as the sheet it was sent to Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted Friday at 03:01 PM Author Share Posted Friday at 03:01 PM 4 hours ago, Renerabbitt said: The callout tool can produce a callout that can link to an elevation camera and post its reference information such as the sheet it was sent to Gotcha. Is that the same for the callout rose with 4 arrows? I know the singular elevation callout can link to the camera, but am curious if there's a way in Chief to do the 4-arrow callout rose you were mentioning & have it linked as well. Or is the 4 arrow callout rose a CAD block that you manually edit & then have additional single elevation callouts that are providing that link to your plan file? Link to comment Share on other sites More sharing options...
Renerabbitt Posted Friday at 03:03 PM Share Posted Friday at 03:03 PM 1 minute ago, ChiefUserKatie said: Gotcha. Is that the same for the callout rose with 4 arrows? I know the singular elevation callout can link to the camera, but am curious if there's a way in Chief to do the 4-arrow callout rose you were mentioning & have it linked as well. Or is the 4 arrow callout rose a CAD block that you manually edit & then have additional single elevation callouts that are providing that link to your plan file? the callout tool is the same whether you add 1 arrow or 4 arrows to it, give it a shot Link to comment Share on other sites More sharing options...
