ChiefUserKatie Posted 4 hours ago Share Posted 4 hours ago Is there a way to easily reorder elevations? We do a lot of whole-home remodels, which means we end up with elevations in nearly every room. I try to organize them correctly from the start, but realistically I don’t always get them in the right order. Sometimes I forget to add an elevation until later, and then I want to reorganize them so the plan set flows better. When you have 20–30+ elevations, it becomes pretty tedious to go into each one and manually rename or renumber them. Is there a way to automatically sort elevations? Ideally, I’m imagining a feature where all elevations could be shown in a list and you could drag and drop them into the desired order, with the elevation names or numbers automatically updating based on that order. Thanks in advance for the help! Link to comment Share on other sites More sharing options...
basketballman Posted 3 hours ago Share Posted 3 hours ago P. M. sent .. Link to comment Share on other sites More sharing options...
SHCanada2 Posted 2 hours ago Share Posted 2 hours ago are you referring to changing their location in layout, or just renumbering/naming? Link to comment Share on other sites More sharing options...
