jtcapa1 Posted yesterday at 01:18 AM Share Posted yesterday at 01:18 AM I'm needing to create a custom set of cabinets that lives underneath the stairs, but I was wondering if anybody with rabbit ears has a simple method for changing the tops of my cabinets to fit or align with the slope of the stairs? Link to comment Share on other sites More sharing options...
MarkMc Posted 22 hours ago Share Posted 22 hours ago (edited) Here's a plan with some ideas on how to do that. Plan is old, originally in X13, and don't remember for sure how I made the door. Might be with the wall cabinet on the floor. Nowadays I'd make the door from a countertop with molding added, convert to cab door symbol and rotate. Taking a detail from view of elevation of stairs is the easy way to get the angle to use. Under stair cabinet.zip Edited 22 hours ago by MarkMc Link to comment Share on other sites More sharing options...
DBCooper Posted 21 hours ago Share Posted 21 hours ago Angled top cabinets are not very easy since Chief is not designed to build them. For your situation, you could try just using a normal door. In the picture below, I made it "triangle arch" top and made it "right arch" instead of angled on both sides. I then removed the casing and jamb. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 18 hours ago Share Posted 18 hours ago (edited) This is from my paywalled member section, 16 Min video, I set it to public for today only Jan 20, 2026 Edited 18 hours ago by Renerabbitt 1 Link to comment Share on other sites More sharing options...
