DefinedDesign Posted yesterday at 01:56 PM Share Posted yesterday at 01:56 PM Attempting to dimension both these closed polylines objects . Each time I try to dimension the left and right sides it deletes the measurements, why is this and how can I fix it? I need to dimension both sides of both objects. I have tried using manual on one side and end to end and/or point to point and I get the same results. Grateful for anyone who can provide a solid solution, this is most frustrating. Link to comment Share on other sites More sharing options...
CharlesVolz Posted yesterday at 04:32 PM Share Posted yesterday at 04:32 PM Not sure why you are having trouble, but if I were having trouble, I would probably just use point-to-point dimensions or insert points, then dimension the points and move them to the correct distances, then snap the polyline to the points. Link to comment Share on other sites More sharing options...
rwdozier Posted yesterday at 06:32 PM Share Posted yesterday at 06:32 PM No problem here. Angle snaps off? Link to comment Share on other sites More sharing options...
CharlesVolz Posted yesterday at 07:03 PM Share Posted yesterday at 07:03 PM 31 minutes ago, rwdozier said: Angle snaps off? Grid snaps off? Link to comment Share on other sites More sharing options...
DBCooper Posted yesterday at 07:51 PM Share Posted yesterday at 07:51 PM Check your dimension defaults to see if locate objects is set properly. Are you working in a cad detail or plan view? Is it really just a polyline, or is it something else? Is it being draw using reference display or is it in a cad block? Are you trying to dimension to something on a layout that is really in a plan view? So many possible reasons which is why you might want to post the plan. Link to comment Share on other sites More sharing options...
