Porch w/ Cathedral ceiling, no gable shown
myrtsbnye
Hello all, Doing a project that has a grand porch with a cathedral ceiling. When the flat ceiling is checked for the porch the gable is shown. But when I uncheck the flat ceiling the gable disappears and place a cathedral ceiling in it's place the gable doesn't reappear. I've clicked the railing and in the roof section have clicked on the full gable wall. What am I doing wrong?
I'm using X16.
I'll attach a basic pic showing the missing gable wall
1 hour ago, Garybills said:
You can manually draw an attic wall to get a wall in the gable end if you're wanting it closed in with cathedral ceiling inside.
Thanks for your reply, the client is looking for the gable to follow the cathedral ceiling.
You can also manually draw an attic wall and set to "Roof cuts wall at bottom." I'm not in Chief right now and can't test it but this should work. You may need to extend the ceiling planes into the wall space slightly.
