JAWRIGHT Posted August 22, 2025 Share Posted August 22, 2025 We do many home with classical details and columns. Why does Chief not have a tradtional Tuscan column? Is there a way to add or download one? Link to comment Share on other sites More sharing options...
joey_martin Posted August 22, 2025 Share Posted August 22, 2025 https://3dwarehouse.sketchup.com/search/models?q=tuscan+column&hl=en Link to comment Share on other sites More sharing options...
DBCooper Posted August 22, 2025 Share Posted August 22, 2025 (edited) If you can't find something in the core libraries, you should check the bonus libraries to see if one is available. I didn't see one but I didn't spend much time looking. The next place I would look is 3D warehouse to see if there was one I could download. Be careful about surface counts though because some of the stuff there has way too many surfaces which is fine if you only need one column but if you need a bunch of them it might really hit your performance. The other solution is to build one yourself using the modeling tools in Chief. Or if you prefer, another 3d modeling program that you already know and use. And lastly, you could always request that Chief build one and include it in their libraries here: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Edited August 22, 2025 by DBCooper Link to comment Share on other sites More sharing options...
PitMan71 Posted August 26, 2025 Share Posted August 26, 2025 it would be great if someone had the HB&G line of columns. Link to comment Share on other sites More sharing options...
robdyck Posted August 27, 2025 Share Posted August 27, 2025 21 hours ago, PitMan71 said: HB&G line of columns @JAWRIGHT Are these close? https://3dwarehouse.sketchup.com/by/FineHouse#models https://3dwarehouse.sketchup.com/model/d370f1c43d77c976e79d181dec16bca/B-Tuscan-Columns-Round-Smooth As far as creating HB&G posts, that's pretty simple on an as needed basis. Simply trace the product drawing at the correct scale and use it as a molding profile on a circle or square polyline converted to a molding. Obviously this wouldn't work for carved capitals. Link to comment Share on other sites More sharing options...
