Plan Macros in Layout File
chrismac
How do I setup a Macro in .plan file and get that same macro to display in Layout file? (Plan linked to Layout) I tried doing %plan.macroname% in Rich Text in Layout, but it's not working.
Open the macro in the plan file using TMM.
Highlight the text and use Ctrl_C to copy
Go to the Layout file and open TMM
Create a new macro
  Name it the same as the plan macro
   Past the contents and save
No guarantee that it will work unless it's non-evaluate since very few objects in Layout will have the same NVPs as the objects in Plan.
you cannot.
You can copy the macro from the plan and recreate in layout(per Joe), if the underlying logic and data are available in the layout (not many data are). Or do as john indicates, assuming, the macro displays to a text box or schedule, or something that can be seen.  For instance, I have a macro that calculates the total living areas of all floors. It shows in a rich text box in my plan, off to the side. I then have just this little text box showing  in my layout on the first page, as I have cropped the first floor plan sent to layout to just show this text box
