FREELBR Posted June 26 Share Posted June 26 No matter what setting I change I can not get my 2X6 walls set to 16" on center. Just did an update and was wondering if anyone else has seen this issue Link to comment Share on other sites More sharing options...
richoffan Posted June 26 Share Posted June 26 Open wall dbx. > wall type > define > framing > set spacing to 16 > rebuild walls, floors & ceilings 1 Link to comment Share on other sites More sharing options...
FREELBR Posted June 26 Author Share Posted June 26 I have tried that and still didn't work. I'm using Premier X17 Link to comment Share on other sites More sharing options...
DBCooper Posted June 26 Share Posted June 26 See if this helps: https://www.chiefarchitect.com/support/article/KB-00907/specifying-the-on-center-oc-spacing-for-wall-framing.html If not, then try posting the plan. Link to comment Share on other sites More sharing options...
robdyck Posted June 27 Share Posted June 27 There are 2 possible settings to adjust wall stud spacing: Automatic Framing Defaults>Wall Wall Type Definitions: adjust the framing layer to use the default setting for universal control from Automatic Framing Defaults or assign a stud spacing specific to that wall type. By default, in at least some of Chief's template plans, at least some exterior walls do NOT follow the Automatic Framing Defaults. In my opinion, a template plan should be set up so that exterior walls DO follow the Automatic Framing Defaults. Link to comment Share on other sites More sharing options...
FREELBR Posted June 27 Author Share Posted June 27 I have tried all suggested setting and still wont change to 16" OC. Here is the file any help would be greatly appreciated GARAGE ADD.plan Link to comment Share on other sites More sharing options...
Doug_N Posted June 27 Share Posted June 27 Here is the solution to your problem! 1 1 Link to comment Share on other sites More sharing options...
FREELBR Posted June 27 Author Share Posted June 27 Thanks for the tip was the only setting i have over looked Link to comment Share on other sites More sharing options...
Doug_N Posted June 28 Share Posted June 28 My pleasure. By the way it would be a good idea to update your signature so that other members can see more about who you are, and what your hardware is like. Sometimes that can make a difference. To update your signature in Chief Architect, you need to access your account settings and update the signature field. You can do this by clicking on your username at the top right, navigating to Account Settings, and then finding the Signature option. Once there, you can modify or replace your existing signature. Here's a more detailed breakdown: Locate Account Settings: Click on your username or profile icon, typically found in the top right corner of the Chief Architect interface. Access Signature Settings: Within the account settings, find the section related to your signature or profile information. This might be labeled as "Signature" or "Profile". Update Signature: You can then edit or replace the current signature with your updated one. Link to comment Share on other sites More sharing options...
