Print File Size
Dhackworth
Go to solution Solved by Joe_Carrick,
I have a project that was created in X16 and when printed as a pdf the file size was 9,631 KB. I've revised the project in X17 just adding a few notes, dimensions and 4 short CMU walls. When I print this in X17 as a pdf the file size has swollen to 48,692 KB!! The pdf file is now so large I can't email it to my client.
Has anyone else run into this and if so, have you discovered a workaround?
Well (he says sheepishly)........ Mr. Carrick, YOU ARE THE MAN!!!
I used a third-party pdf printer a while back and set the dpi to 1200. After reading your post, I went back and changed the printer to the internal Chief printer and set the dpi to 600. After printing with these settings, its now 8,287 KB!
Thanks Joe!!!!
12 minutes ago, Gawdzira said:
Just an FYI, for 24x36 con docs I have the dpi set to 144. Images and all. I only bump up to 300 for 11x17 design development prints.
Thanks for the info. I'll give it a try.
