Dhackworth Posted June 12, 2025 Share Posted June 12, 2025 I have a project that was created in X16 and when printed as a pdf the file size was 9,631 KB. I've revised the project in X17 just adding a few notes, dimensions and 4 short CMU walls. When I print this in X17 as a pdf the file size has swollen to 48,692 KB!! The pdf file is now so large I can't email it to my client. Has anyone else run into this and if so, have you discovered a workaround? Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted June 12, 2025 Solution Share Posted June 12, 2025 What DPI setting are you using for the PDF? 1 Link to comment Share on other sites More sharing options...
Dhackworth Posted June 12, 2025 Author Share Posted June 12, 2025 Well (he says sheepishly)........ Mr. Carrick, YOU ARE THE MAN!!! I used a third-party pdf printer a while back and set the dpi to 1200. After reading your post, I went back and changed the printer to the internal Chief printer and set the dpi to 600. After printing with these settings, its now 8,287 KB! Thanks Joe!!!! Link to comment Share on other sites More sharing options...
Gawdzira Posted June 12, 2025 Share Posted June 12, 2025 Just an FYI, for 24x36 con docs I have the dpi set to 144. Images and all. I only bump up to 300 for 11x17 design development prints. Link to comment Share on other sites More sharing options...
Dhackworth Posted June 12, 2025 Author Share Posted June 12, 2025 12 minutes ago, Gawdzira said: Just an FYI, for 24x36 con docs I have the dpi set to 144. Images and all. I only bump up to 300 for 11x17 design development prints. Thanks for the info. I'll give it a try. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 12, 2025 Share Posted June 12, 2025 I use 300 all the time and send clients a link to download. 1 Link to comment Share on other sites More sharing options...
kMoquin Posted June 12, 2025 Share Posted June 12, 2025 I use 300 dpi and use the compress option on this site (https://www.ilovepdf.com/) if the file is still too large. 1 Link to comment Share on other sites More sharing options...
