New Idea To Export and Backup X17 Project Files Within The Project Manager?
Steve_Nyhof
Now that X17 is out, I want to bring this topic up to a larger audience. Sorry it is a bit lengthy, but read it through carefully as this is very important if you want a more common way to backup your Projects.
If you want to see a video where I go over this click the link below...
https://my-plan.stevenyhofdesigns.com/v/Hid8hQZgCivkhlZPBQft
I would like to preface this post by stating that I love Chief, and use it every day to make a living. Even with its shortcomings and having to create work-arounds to do things, it is still an increasable piece of software. We lose sight of this now and then when we get caught up in something that is failing or frustrating to figure out. I believe the current Project Manager and backup system falls short of what we need as users to operate within this new X17 management system effectively.
I also want to encourage you, the reader of this post, if you are an avid user of Chief and want to see it improve, then do not be silent on this topic. Share your thoughts and ask some questions. I do not claim I fully understand how all the moving parts work, and what I am proposing may not be the solution. But I am hoping that this post will generate some conversation that convinces Chief to take a closer look at what we now have and what is missing that will change how we interact with the new Project Browser that manages our Projects.
PM = Project Manager or the Project Browser
CP = .caproj - The extension used on Exported Projects
HD = Hard Drive or Local Disk
CS - Cloud Service or Online Backup Software
BS - Chiefs built in Backup System
I want to share what I understand about the PM to this point...
Autosaving the Projects:
As you are working within the PM and saving your work, the .plan and .layout files (I believe other file types) are also being saved to your HD. Therefore, your work is being saved to disk, but it is not backed up to a CS.
Chiefs Backup System:
Built into the new X17 PM is a new BS. This backup system, backs up your entire system, your toolbars, hotkeys, user library, etc. and the PM Projects. Each time the BS is run, typically in the evening and currently with Chief software running, it produces a .zip file with a date and name stored in a default system folder or a folder of your choice. Based on my approximate 20 projects, I am exporting close to 5GBs with this one zip file. The backup file contains your Projects that you can access by opening the file.
If you want to make sure you are backing up your work to a CS you need to select the root folder of these ever growing BS files. If you are like me, I want to make sure that my work is backed up on a CS each night in case of HD failure in any way. It does not take extensive math skills to know how quickly you will be increasing your storage both on your HD and with the CS as your projects grow. This to me in unsustainable nor practical. To say it differently, I do not need to backup my user library everyday. I have it manually exported to my HD where it is backed up by my CS. My CS checks my library files to see if anything changed (a new export) and backs it up if changed.
I want to add that there is a number of backups that you can set (called Retention) before the system will remove the oldest backups. So it is not as though the storage will continue to grow, but with a retention, it also means that the Projects that have been saved in this backup file, that you may want to access later, will in time be deleted from your HD.
Personal Side Note:
I am using the PM for only the work I am working on to keep my projects manageable. Meaning, at the moment, I am Exporting my projects manually that are being worked on and completed so they are backed up to my HD and CS. I delete the Projects from the PM that I no longer am working on. This helps keep the file size of the BS file lower. But this is the very reason I am bringing this subject up. The current BS is not a solution for a daily backup system.
.caproj file type and Exporting Projects:
The .caproj (CP) file is a renamed .zip file extension. It is a zipped file that contains all your project files, your .plan, .layout, and other file types you use within the project, within the PM. I have opted to manually Export my project(s) as stated above that I work on each day to my HD so that my CS can backup these files.
The CP is a self contained file that also includes your assets. (See below). Because it is a single file, it can be treaded like any software file. Like your .plan and .layout is now treaded, saved to your HD and backed up and shared with your colleagues over your CS. The Exported Project file with the extension of .caproj is in my mind the new Chief file type. This does not mean that you cannot export a single .plan or .layout, you can and for various reasons you will.
But I am bringing attention to a shortcoming in the PM that I want Chief to consider.
Assets:
Assets are now very intuitive in X17. I am bringing this up only so that others may expound on this topic within this topic.
Proposed "Project Backup" System:
The BS has a lot of power in being able to transfer an entire Chief eco system containing your toolbars, hotkeys, libraires, projects, etc.. I am not suggesting that this be replaced as I also know that it is a part of a Chief cloud backup and sharing system still being developed. The BS is also very cool as I in one step backed up from my Desktop everything, and Restored it to my Laptop - BOOM! Now both systems are exactly the same. But would I do it again? Not if I am making changes to projects on both computers? Nor am I interested in running a large backup just to work on a project on another computer. I would need to be on top of this each time I sat down by the next computer. Thus the reason for this post.
What I am proposing is an additional backup system for Projects themselves to a specified local folder on your HD. These Project Files, because they are a self contained file type (.caproj) can be treaded SIMILAR to a typical SAVED file, like .plan. A backup of these Project files would be a copy of the files that are currently in the PM and saved within the Chief software. That is why I say this would be SIMILAR to a SAVED file.
In X16, a .plan file would be opened and saved to your HD in a specific folder. Saving this .plan file while working in Chief, is in fact, overwriting the .plan file saved on your HD. With each save the .plan is updated with the new data.
In X17, the PM is storing your plans in a format called, Projects, and saved to your HD within the control of the Chief software. Meaning, in this current state, the file you are working on within the PM is not currently accessible in a folder that you control. Only through the BS can you gain access through a ZIP file, and to your Projects. If you are sophisticated in a higher understanding of backup software you might be able to automatically dig into this ZIP file and extract your projects. Or do it manually. But that again is not practical, nor typical file organization.
WHY are we being asked to give up our very common control over our work? The simple answer is that Chief has built a system that is designed to prevent the breaking of links and assets. This is a good thing as the current X16 backup plan is still often missing assets or has broken links between the .plan and .layout. All previous version of Chief has had this problem and caused a lot of headache for Chief and its users. If you are wondering why this big change in X17, this is why? But it has come with a side effect I am trying to bring attention to.
The "Project Backup" system would be an additional backup system with Chief that can run each night (preferably without Chief software being open), saving our projects to our HD so that our CS can backup these Projects to be stored and/or shared with a team.
There are some details about the options of this backup I have not sorted out, but I think the backup needs to OVERWRITE the previous backed up Projects so that they are always current, or the latest data, just like a saved file OVERWRITES itself on our HD so it has the current and latest data.
Just as a .plan saved file is shared now with another computer, it is a copy of the .plan file still on disk. Therefore, just like a saved file, an Exported Project file (.caproj) is made a copy that can be shared, and therefore must also overwrite the original after it is worked on, so that the original again contains the latest data. We are responsible for this process as we have been.
Through a process of backing up each evening our Project files, we can be confident that our work is saved, backed up locally and within our CS, and available to be accessed and shared as we have done for years.
NOTE: If the project is now saved to disk and backed up to our CS, we can then also DELETE it from the PM. We do not need to store our completed Projects within the PM if we chose and want to make the PM more manageable. But this Project Backup system needs to operate so that this can be an automated process that we can be confident is saving our work each day to our HD, so that our CS can also run each day.
As you have read, there are some moving parts here that need to be understood to operate in a team environment or even a single user that jumps between computers.
Syncing:
A brief note on syncing. I use a CS called IDrive. It can do versioning so I can always go back to a previously saved file if I need to access something within an older drawing. But I also use Google Drive and Syncing because when I move between my desktop and laptop, I can download this project file to the computer I am working on and Import it into the PM, make my changes, and then Export it back to the main folder I took it from, which then again syncs the file, overwriting that the original file so that it is now current with the latest data.
Please share your thoughts and questions
  • Upvote 2
The one thing I just found out is that if you have a folder added to a Project, that folder remains with the Exported Project. When you import that Project later into the PM, it already has the same folder applied. That is very nice!
  • Steve_Nyhof changed the title to New Idea To Export and Backup X17 Project Files Within The Project Manager?
i think because CA is going to the cloud, this is just a temporary limitation.. If you are worried about HD failure, then I would suggest backing up CA's backup, or just do the entire CA directory where it stores everything. For file sharing I would suggest keeping to non PM mode if you use a shared replicated drive.
And so you are ok with waiting on CA to implement their Cloud as your go to cloud service? Have you looked at how their other online services work in your account? Like 1990's! Based on their track record of 80% to 90% implantation of their tools, I am not so optimistic that once their CS is rolled out that we will not be asking for more and more to actually make it work properly. I love my versioning that already runs and works perfectly with my CS. Others I am sure have their methods as there are many options today with the various CS's.
I do agree they want to implement their original plan for this for investment sake, and I honestly am fine with it... IF...    I am asking for an additional backup tool if some of their users want to control the Projects with their own CS. Again, I am more concerned personally for backing up my work in a way I have done for years and with my own CS, but it will be the teams that for now could benefit from what I am proposing.
Added: Or give me some good reasons why backing up the CP's is not a good idea. Or why it is a bad idea?
well, I have not yet setup my backup for X17, but I will probably just back up the entire directory. I do not backup to cloud I just back up to another HD. My internal drives are raided so I have some protection even without the backup.
So to answer your question, I am fine, cloud or no cloud. But if I was using cloud for internal file sharing today, then I would want CA's implementation of cloud to allow it to be used by one's own cloud service, and not force to use CA cloud.  ...but that is easier said than done I would think. If I was speculating, CA cloud service would be at a minimum a data store, with synching locally. And if that did not work, then I think, yes, you would have a large issue as the "workaround" would be exporting files and moving them between users.
I suppose what I am suggesting, is wait and see. But from a pure backup file only perspective, I personally am not concerned. CA still stores the .plan and .layout files on disk, unencrypted, but with obfuscated names. If I was very very desperate after a catastrophic event if for some reason the CA backup .zip files were not readable,  I could always look at last modtimes for these obfuscated .plan files and find the one I need and rename it and use it.  In other words, CA via its backup has multiple copies of .plan files...plus there is the current version of the plan file. Lots of backups on disk. One just has to choose what to sync to a backup cloud service if one wants to use that.
Its the file sharing that, in my view, will need to be working very very well with the cloud, or people will not be able to use PM mode. File locking across WANs is not trivial, timezones, DST, no network connectivity, all have to be taken into consideration. Major software products today are still not smart enough to do something as simple as tell me when someone else in a different timezone changed something.  And the reason is these software products must maintain a last modified time and know the timezone it was modified in. The software programmers often think they can just use a one central time, but that only work when everyone is always connected. For instance if I download a file, get disconnected from the network, modify the file, and then change the timezone on my computer and then get network connectivity back, is the mothership smart enough to know exactly when things changed?
2 minutes ago, Steve_Nyhof said:
Thank you for taking the time to share all this. Very informative! I do need to dig into Chiefs backup more to find out what I have access to.
goto the preferences settings, and goto PM, it lists the backup directory. If you then goto that directory you should see the zip files (assuming you set up backups to occur). And then if I was you, I would point your backup service to that directory. And because the backups are full backups, I think you could just have your backup service backup the latest file in that directory...if you can configure your backup service to do that. If not, use the CA number of backups to keep, also in preferences, to keep that list to something small.
Yes, I have this all set up, but I need to dig into what is backed up and learn more about how and what is being backed up beyond the norm.
I will add, that why do I want to dig into some other file and folders to gain access to my Projects? When has that ever been ok with standard files. This isn't about how clever we can get, it is about keeping it simple and automated so we do not lose any work - ever!
Subject: Why I’m Opting Out of Chief Architect X17’s File Management System
After spending some time with Chief Architect X17’s new File Management system, I’ve decided to opt out — and I wanted to share why, in case it resonates with others who work solo and value simplicity.
At first glance, the File Management system promises structure and automation. But for those of us who’ve been managing projects effectively on our own — using clear folder hierarchies, consistent naming, and disciplined backups — it adds layers of complexity that don’t feel necessary.
It seems like a solution to a problem I don’t have.
The system introduces rigid folder structures, enforced naming, and automatic file linking, which may be helpful in team environments or for those just starting out. But if you’re already methodical, it begins to feel like Chief Architect is now micromanaging what used to be intuitive.
For example, I already organize my projects by client, keep plan and layout files in clearly marked folders, and archive my own dated versions. I don’t move files once linked, and I’ve never run into a situation where I lost track of a .plan or .layout file. So I asked myself: If it’s not broken, and not in need of fixing — then what’s the point?
Yes, autosave still works as it did in X16. Yes, I can still manually manage backups. And no, I don’t need a system enforcing rules I didn’t ask for, especially when it interferes with the clarity and rhythm of my own workflow.
To be fair, for teams, or newer users, this system may absolutely be worth it. But for seasoned solo professionals, it feels like a layer that solves someone else’s problem — not ours.
Just thought I’d share, in case others are on the fence. If you’ve already got a workflow that keeps you organized and backed up, skipping File Management is not only fine — it might even keep things cleaner.
  • Upvote 2
On 5/29/2025 at 5:30 PM, DRAWCO said:
This new system is very confusing.
Agree with this observation. Presumably, newer users may or may not have a method for keeping everything in its place, and perhaps they may be the target audience.
There’s definitely a benefit for a team setting — and perhaps that’s where X17 shines. But as for my personal choice, this feels like a feature that’s geared more toward solving workflow chaos than enhancing precision.
If a poll were taken, I’d say the silent majority of experienced solo users won’t be using it. Not because it’s bad — but because it introduces more rules than rewards for those of us who already work cleanly and deliberately.
Sometimes structure is helpful. Other times, it just slows down momentum. This feels like the latter.
  • Upvote 2
Hi Val,
I'm in the same boat but I have additional problems with the PM.  One major problem is the inability to read/write external files with Ruby.  I hope CA will fix that and simplify the PM.  If so I might use it - but I'm not holding my breath.
BTW, the PM also causes some problems with timing of macro operations.
I disagree, updating a template has never been easier. dragging and dropping is a dream. duplicating a complexed linked layout template is super easy. navigating to my projects is faster...like way faster. versioning is faster.
On the flip side, team collab is way more convoluted in project management
21 minutes ago, NewTexan said:
Was PM functionality such a big user request for CA?
inadvertently yes. Huge number of support calls on broken links from people who do not understand where texture files are stored and search for and why renaming a file breaks a linked layout
Joe I am curious, I keep giving a method for this, I am able to read..I have never checked write, and I am using PM.
My main gripe is no NVP for the folder tags
I can see why if you do this seperate folders between plan and layout, the new PM is not making it any easier.
I always had mine in the same folder, so I see no real difference in the PM project view today. A PM project is just what I used to have for a folder.  But it would be easier to navigate if there were folders within the project that I could move off copies of the plan that I use as a versioned plan, to
I sent in some improvements on the naming. I find the options on the right click confusing as to what they will do.
My problem is the text files are in my plan folder and I don't have a way to identify that in the PM.  If they were just in a fixed Windows Folder it would work but in my use case they have to be in a project specific folder.  I didn't see a way to get that.  The NVP is probably what's missing.
I've brought this up before in other threads where you mention this and I haven't seen a response.. I know its not perfect but it does work if you give a static main projects directory and then search for your project by project name. I am able to find my csv files from the project and plan name nvp's in that way automatically so long as I give a static master projects directory
Seems a bit complicated.  Can you show screen shots of this setup or a video?
heres the video, keep in mind we can obviously partition the Project name such as a Project Name: Jerry Dr - Design A
and then put this in a polyline:
%splitter="%project.name%"; parts=splitter.split(" - "); $project_name=parts[0]; $version_name=parts[1]%
and in the same polyline:
%$client_name="%client.name%"%
and then in your file lookup:
$dir="C:/Users/rener/Dropbox/Projects"
path = "#{$dir}#{$client_name}/#{$project_name}/#{$version_name}/Client Info.csv"
See vid:
Thanks Rene,
My way of getting the path to the project has historically been different, relying on different NVPs.  Your explanation should help me revise this - still resulting in a $global.
It will take me a little time to ensure that it's working.
See you at Couer d,Alene in August.
