Michael_Gia Posted Wednesday at 01:06 PM Share Posted Wednesday at 01:06 PM Hey, I'd love to upgrade to X17. I now see that big beautiful green UPGRADE button teasing me... Is it too early? Any issues? Link to comment Share on other sites More sharing options...
Adam_Gibson Posted Wednesday at 01:12 PM Share Posted Wednesday at 01:12 PM No issues. It is solid. Managed Projects will take some getting used to. 2 Link to comment Share on other sites More sharing options...
AlexLifespan Posted Wednesday at 05:07 PM Share Posted Wednesday at 05:07 PM I was just doing some stress testing with rendering. Using PBR with modest settings, and without a structure in the plan - just the generated sky and no terrain, I am hitting insanely high temps (98-100c) with my watercooled 13900k. CPU utilization jumps to 100% whenever I move my camera or adjust the active view. I have not had this issue with x16. If you do try it out, keep an eye on your temps. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Wednesday at 05:28 PM Share Posted Wednesday at 05:28 PM Managed projects has multiple ways to be used based on your desired workflow. Common Documents seems to be for warehouse type template plans Link to comment Share on other sites More sharing options...
para-CAD Posted Wednesday at 05:41 PM Share Posted Wednesday at 05:41 PM Every time I start it, it says I'm missing Century Gothic font. I don't use that so it must be from a template I bought or plan I collaborated on. And today upon closing it asked if I wanted to perform the scheduled back up.....so that's cool. Link to comment Share on other sites More sharing options...
Dominic900 Posted Wednesday at 05:44 PM Share Posted Wednesday at 05:44 PM 26 minutes ago, AlexLifespan said: I was just doing some stress testing with rendering. Using PBR with modest settings, and without a structure in the plan - just the generated sky and no terrain, I am hitting insanely high temps (98-100c) with my watercooled 13900k. CPU utilization jumps to 100% whenever I move my camera or adjust the active view. I have not had this issue with x16. If you do try it out, keep an eye on your temps. Hello Alex, If you have not already done so you may want to report your issue to tech support as that is not suppose to happen. I ran a test this morning and it runs normally had a plan open and did a rendering and computer acted normal so did CA x17 beta 3. Did not run temps test but everything ran fine on my end. Plan file was not to detailed in 3d view. I did notice how fast rendering was done both standard and PBR and PBR was faster than X16. Did you have anything running in the background while rendering? I make sure that nothing is running except what is required to for a computer to function while running chief. I hope this info helps you. Kind regards, Dominic Link to comment Share on other sites More sharing options...
