Itching to try X17, is it safe?
I was just doing some stress testing with rendering. Using PBR with modest settings, and without a structure in the plan - just the generated sky and no terrain, I am hitting insanely high temps (98-100c) with my watercooled 13900k. CPU utilization jumps to 100% whenever I move my camera or adjust the active view. I have not had this issue with x16.
If you do try it out, keep an eye on your temps.
Every time I start it, it says I'm missing Century Gothic font.
I don't use that so it must be from a template I bought or plan I collaborated on.
And today upon closing it asked if I wanted to perform the scheduled back up.....so that's cool.
Hello Alex,
If you have not already done so you may want to report your issue to tech support as that is not suppose to happen. I ran a test this morning and it runs normally had a plan open and did a rendering and computer acted normal so did CA x17 beta 3. Did not run temps test but everything ran fine on my end. Plan file was not to detailed in 3d view. I did notice how fast rendering was done both standard and PBR and PBR was faster than X16. Did you have anything running in the background while rendering? I make sure that nothing is running except what is required to for a computer to function while running chief. I hope this info helps you.
Kind regards,
Dominic
