Monthly subscriptions?! Hard "no". Best alternative 3D software?
OK, well, I'm back. After 4.5 years off!
But I may be off again... as I've just seen the subscription-only pricing. Wow.
Doesn't work for me. At all. Sorry. I'd rather spend the next 12 months learning another software than get locked into a monthly subsciption for software that dies the minute I stop paying. Especially software that charges as much in a couple of years as it used to cost to buy it outright. It just doesn't make sense to my business model as an on /off user and I'm actually strongly against it on principle.
Any ideas about likely alternatives? Are there any?! I'll obviously do a lot of Googling and download some trials, but this forum was always a huge strength of CA, so I'll keep this tab open to look for replies. I'll also drop back once in a while to see if the pricing has got more flexible.
I'm pretty shocked. And sad.
  • Upvote 2
  • Downvote 1
Your X8 version should still work.  If you kept the SSA each year you should be able to download the newer versions up to X14.
AFAIK Chief hasn't terminated any old licensed versions.  The subscription model is only for new users.
At some point in the future I may decide to not upgrade and forgo SSA - depending on if I think future versions will provide  additional capabilities I will use.
Chief still has a lot of room to add features and improvements so I'm not there yet.
ps: I'll be 83 next month so I can't say how long I will need to keep up the SSA. :lol:
Andy, Thank you for the question and feedback.  If you are an "on/off user" you can consider the monthly option.  The monthly option can be turned on and off as needed monthly and is $229 per month.  This is often a good fit for those doing occasional projects.
Kind regards,
Derek Pedersen
Chief Architect Software
I am not a big fan of the subscription model used by many software vendors of late. I will say Its nice to have the option to turn it off when not needed for those of us working part time but I have come to use the software in many ways which requires I keep a copy active. Most of the competition use subscription models now so there really isn't another option where the user can actually purchase the software any more.
That said, I have watched the progress of the Home Pro Software over the years and have used it on various design / con doc jobs. For $595 initially and a $119 upgrade cost per year, I am just about to the point where it will serve my needs at a very considerable cost difference as compared to $229 per month ($2748.00 yr) I have adapted many routines to make it work just fine for standard con docs. Just a thought....
