ACADuser Posted March 25, 2015 Share Posted March 25, 2015 I have seen a S Hall video on this but can't for the life of me find it again. Trying to remove the partition so the raised doorway actually joins the full doorway to eliminate the partition. Point me in the direction please. Thanks Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 25, 2015 Share Posted March 25, 2015 I think the smaller unit is a window. If you make it a window the partition should go away. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 No joy, I tried that first. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted March 25, 2015 Share Posted March 25, 2015 Do you have your minimum separation set to 0"? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 25, 2015 Share Posted March 25, 2015 Have you considered using a full width doorway and a half wall inside that? There are several ways to accomplish this - that would probably be my choice, but you could also use a divider wall and a half wall. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 I changed back to a window pass through with min. seperation set to zero & still has a partition. Joe, I will try the half wall. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 Well half wall still has a partition. Is there a min, separation for doors? Don't like the fact that I now have to build a soffit to fill in above the opening left by the half wall. Scott, wake up. The sun should be coming up in California about now. I'm pretty sure Scott was using door ways & the video was to help someone with arched or round top doorways & thick walls as I remember. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 25, 2015 Share Posted March 25, 2015 Alan, Is this what you are trying to do? The 1st pic uses a Divider Wall and a Half Wall. The 2nd pic uses a Half Wall, No Room Def moved into the opening created by a Doorway. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 Yes, but I figured out what is going on. When you add an arch to one of the doorways it will join. That's what Scott was using. Here is a 0.25 arch Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 Joe, what did you use to fill in above the half wall? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 25, 2015 Share Posted March 25, 2015 I used a Soffit. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 Thanks Joe, My knowledge is so limited I don't see all the options yet. But things are getting better. Here it is with a 1/16 arch, that was the key all along. I'm just roughing things out so all the openings & knee walls are not correct yet. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted March 25, 2015 Share Posted March 25, 2015 If you use a doorway and pass through with no casing and set the frame for the window to 0, minimum separation 0, it will show OK. Link to comment Share on other sites More sharing options...
ACADuser Posted March 25, 2015 Author Share Posted March 25, 2015 Thanks for your time Dennis, I think I did not set the frame width but did set separation to 0. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted March 25, 2015 Share Posted March 25, 2015 Alan - I had to go back and check how I did it. I forgot about the frame width myself. Link to comment Share on other sites More sharing options...
