Chiefnewell Posted January 15 Share Posted January 15 i am trying to create a L shaped stairs on this remodeling with bottom portion wider than landing and 4 steps to 2nd floor. Is this possible? sloped ceiling at 3'4" width hallway on side. Is this possible? Link to comment Share on other sites More sharing options...
Chiefnewell Posted January 15 Author Share Posted January 15 Sorry I did not attach the file before i am trying to create a L shaped stairs on this remodeling with bottom portion wider than landing and 4 steps to 2nd floor. Is this possible? sloped ceiling at 3'4" width hallway on side. Is this possible? 2 Eolmer Remodeling 2 bedroom up 01.09.2024.zip Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 15 Share Posted January 15 Create the Landing,& each Stair Section separately. Then just connect them. Link to comment Share on other sites More sharing options...
Chiefnewell Posted January 15 Author Share Posted January 15 Joe, I have an issue connecting each of the stairs to the landing. Newell 2 Eolmer Remodeling 2 bedroom up 01.09.2024.zip Link to comment Share on other sites More sharing options...
Gawdzira Posted January 15 Share Posted January 15 You may need to make a break along the line of the landing where the stair meets it for the stair to connect. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 15 Share Posted January 15 I just opened your file. The stairs and the landings are at off angles to the walls. Did you meant for them to be misaligned? You will need to clean up the angle before you can snap it together. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 15 Share Posted January 15 Just a heads up, this is really tight and may not meet local codes. Link to comment Share on other sites More sharing options...
