djhplanning Posted January 14, 2025 Share Posted January 14, 2025 Does anyone know how to make your entire house a cad block for use on a 3d site terrain model? I have done this before about a year ago and can't figure out how I did it. I made the entire house into a cad block and saved it in my user library, then placed it in a separate plan file where I had the 3d site terrain. This way I didn't have to rotate the site terrain I can just rotate and move the building around on the site. Thank you! Link to comment Share on other sites More sharing options...
BenPalmer Posted January 14, 2025 Share Posted January 14, 2025 Referencing the entire model to the other plan is a good option that eliminates the need to create the symbol: https://www.chiefarchitect.com/videos/watch/193/offsetting-the-reference-display.html 1 Link to comment Share on other sites More sharing options...
DBCooper Posted January 15, 2025 Share Posted January 15, 2025 If you want to see it in a camera view, you don't want a cad block. You want to either create a 3D symbol out of the house or use reference display to show it in another plan. Ben posted a link to a video that should show you how to use the reference display. Here is a tech article that will tell you how to make a symbol out of a house: https://www.chiefarchitect.com/support/article/KB-00344/modeling-a-subdivision-or-lot-with-multiple-structures.html Link to comment Share on other sites More sharing options...
Solution jonboy Posted January 15, 2025 Solution Share Posted January 15, 2025 Get the house designs completed then save as 3d symbol then into library, name it then open your site plan and insert it. Click on the symbol to adjust height. Link to comment Share on other sites More sharing options...
djhplanning Posted January 15, 2025 Author Share Posted January 15, 2025 15 minutes ago, BenPalmer said: Referencing the entire model to the other plan is a good option that eliminates the need to create the symbol: https://www.chiefarchitect.com/videos/watch/193/offsetting-the-reference-display.html So far so good. I have the separate house showing up as a reference display in my 3d site terrain but is there anyway to control the elevation height as I am trying to show in on a raised or hill portion of the site. I need to raise it about 30' higher.0 Link to comment Share on other sites More sharing options...
BenPalmer Posted January 15, 2025 Share Posted January 15, 2025 Try adjusting the Z axis. Link to comment Share on other sites More sharing options...
djhplanning Posted January 15, 2025 Author Share Posted January 15, 2025 6 minutes ago, BenPalmer said: Try adjusting the Z axis. I will have to play around with that some more. Thank you very much for your help! Link to comment Share on other sites More sharing options...
djhplanning Posted January 15, 2025 Author Share Posted January 15, 2025 21 minutes ago, jonboy said: Get the house designs completed then save as 3d symbol then into library, name it then open your site plan and insert it. Click on the symbol to adjust height. I believe this is how I did it before! I was missing the part of having to be in a 3d view to have the option to convert to a symbol. I like this method because there is more control over the elevation of the building vs. the site terrain as I can just selected the symbol and manually move it up or down and around. Thank you very much for the help! Link to comment Share on other sites More sharing options...
BenPalmer Posted January 15, 2025 Share Posted January 15, 2025 1 Link to comment Share on other sites More sharing options...
jonboy Posted January 15, 2025 Share Posted January 15, 2025 Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 15, 2025 Share Posted January 15, 2025 23 hours ago, djhplanning said: I believe this is how I did it before! I was missing the part of having to be in a 3d view to have the option to convert to a symbol. I like this method because there is more control over the elevation of the building vs. the site terrain as I can just selected the symbol and manually move it up or down and around. Thank you very much for the help! Why are you building your site plan in a separate file? Why not use the plan with the model, it's far more dynamic, especially since we have additional capabilities when the house is present such as flattening pad and retaining wall intersections Link to comment Share on other sites More sharing options...
djhplanning Posted February 13, 2025 Author Share Posted February 13, 2025 On 1/15/2025 at 5:38 PM, Renerabbitt said: Why are you building your site plan in a separate file? Why not use the plan with the model, it's far more dynamic, especially since we have additional capabilities when the house is present such as flattening pad and retaining wall intersections I suppose I could have. I mainly didn't because I had a helper create the site 3d for me and just had them start with a blank template. Another reason was for computer speed. I'm getting to a point of needing to upgrade my computer as my current iMac is 8 years old and is getting slow with even medium sized Chief files. 1 Link to comment Share on other sites More sharing options...
