madcowscarnival Posted December 19, 2024 Share Posted December 19, 2024 I've never performed this operation before and don't know the correct way to search. I sent a camera view (general reference for a guy) to the layout. The "picture" on layout I want to scale down to fit in a smaller area on the sheet. However, when I use "hold C drag corner" resizing, it just resizes the bounding box, and clips the picture, which remains the original size. Is it possible to resize/scale down the camera view? Unlike the ortho view where I could simply send over at a smaller scale, the options in scaling are grayed out. Thanks all. Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 19, 2024 Share Posted December 19, 2024 use the x key.hold it down while resizing Link to comment Share on other sites More sharing options...
DBCooper Posted December 20, 2024 Share Posted December 20, 2024 I think you might have better luck changing the scale instead. You can do this using the rescale button or using the layout box dialog Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 20, 2024 Share Posted December 20, 2024 1 hour ago, DBCooper said: I think you might have better luck changing the scale instead I use it all the time, seems to always work if resizing from the corners. I resize using the X, and then crop by pulling in the top, bottom, left or right part of the layout box Link to comment Share on other sites More sharing options...
basketballman Posted December 20, 2024 Share Posted December 20, 2024 You can also use SnagIt or any other screen capture Link to comment Share on other sites More sharing options...
kMoquin Posted December 20, 2024 Share Posted December 20, 2024 If you open the dbx for the image you can set the size precisely while retaining the aspect ratio. Link to comment Share on other sites More sharing options...
