Square Foot Schedules
krrbnsn
3 hours ago, SHCanada2 said:
so million dollar question, where is your total for all floors coming from (it's own one line schedule?)
It isn't from a separate schedule. The individual floor values come from CAD poly lines with a macro in the label. The total is a macro formula in a Rich Text box.
1 minute ago, SHCanada2 said:
too bad, I was hoping for a non polyline solution. just be careful if those macros are using global variables. If those are on different sheets than the actual floor, and if you have two open floor plans, you may get results from the other floor plan.
I exhausted everything I knew to get a total from a schedule and came up short.
You are right about the different poly lines on different layers / multiple plans messing up the numbers. I scratched my head and said a few bad words until I figured that out.
There is only one way I know to avoid that, and that is to use the filename as a key/check on the variable.
Did you find another way?
I just keep all of the CAD poly line boxes on my Terrain Working SPV. I just cut and paste to the upper and lower floors - then back again to the home base parked off to the side.  I'm barely out of the staring blocks on macros so there isn't much depth of experience to draw from.
that's the "keep all of the items which contribute to the global variables and the resulting calculations, on the same view" method. That works well, you just cant move the resultant calculations off that view.
I'm guessing with CA doing more and more on work on schedules lately, there will be a schedule solution to this soon
It's greatly appreciated that CA is putting some good effort towards schedules, that's for sure.  Did you ever find out how the other programs handle this total sqft issue?
I have stated this before, and unfortunately this is not one of those things that I would give away for free as others sell a similar system. All I am willing to tell you is that it is totally doable without the need of a rich text box.
My next version of the Pro Plan has an expanded area analysis that is very easy to adapt to many different conditions. It only requires one polyline for the lot size. The rest is done automatically.
no argument that it is not doable, as I already do it as well without polylines (except for the lot),...but it is not implementable in a simple manner.
I just think it should be available OOTB, or described by CA as to how to configure it OOTB. ...in other words a standard(live - non polyline) solution by CA
I just think it should be available OOTB, or described by CA as to how to configure it OOTB. ...in other words a standard solution by CA
There are various rules depending on the jurisdiction so a standard solution by CA wouldn't work except in just a few cases.
IAE, if CA did provide one then the work Rene, Michael, myself and others who sell a system would be devalued.
FWIW, my system using named polylines has no problems with multiple floors because I use one plan for the site and referenced plans for each floor.  All the macros are thereby visible and executed.
On 12/11/2024 at 4:08 PM, Renerabbitt said:
Its only using a global variable for my polyline based Lot Perimeter
well you sort of gave it away at least for the rudimentary totals which have been on all plans since the beginning of time
using the macro I suggested above (which I assume you have similar but maybe not :) ), and using schedules to group similar without the room name one can get the rudimentary floor and living area totals:
I suppose one could then add in any number of additional flags in the OIP for garages, porches, above grade, parcel coverage etc.
and thinking about how SP assigns "areas" for their sq ft totals, I suppose just putting the flag in the room is a similar concept, just not quite as pretty.
I am curious how your snippet above could be done without a rich text box...and if that also includes without shifting if, say a new floor is added. I will have to play around.
I suppose they could just all be text boxes or text boxes and schedules, but then if a floor was added they would need to be moved around. That is the advantage of doing it all in a rich text box with a couple macros...they auto adjust vertical size.
You are making me rethink mine which is currently a rich text box and is fully dynamic with:
AREA SUMMARY
%allarearef_2%
%allarearef_2_basement%
PARCEL COVERAGE
%parcelCoverage%
which yields on layout:
the only downside I see so far is the schedules don't always update with the macro changing the underlying global variable ...I think I saw you post about that a little while ago. I'll have to go back
...and the only other issue I see for using schedules is up here, the city wants to know total above grade and finished area below grade (as that is what the assessment works off of as finished basements only contribute ~10k to the house value), and the schedule tool only allows one to pick one floor or all. I suppose one could put in an OIP or two to add a couple flags, but that seems like a total work around and subject to error
Can you expand on this?
on what they want to see here?
99% of houses in the west have basements. New house plans will typically show the above grade floors and the basement. The basement plan usually shows an outline of a "future" bathroom so that this gets rough in in the concrete floor.
So new house plans will always show each floor sq ft, and the sum of above grade on the first page of the plans (or in the title block). The basement below grade is reported as "finished area" if it is actually being finished (which is rare unless it is a walkout basement). Finished area excludes furnace room.
sq ft for above grade is just the area to the outside walls (includes stairwells, atriums, etc) although I have seen plans submitted to the city that the Architect excludes open to below, my guess to try and reduce the sq ft for property tax assessment purposes. But by bylaw here, sq footage is to outside wall for above grade.
And it is rare to see total sq footage to include basement, even if they are finishing it, as the tax department has two seperate fields (above and below grade sq footage). And the tax guy told me they only assign a value of ~10k. so like ten dollars a sq foot, so no one wants that area to be included in the actual above grade area.
multi family apartment:
Really ???  -  Maybe in some northern areas but not in most of the US.
But the rest of your post just illustrates how every jurisdiction and every home requires different information.
I've needed to show:
  • Property Area
  • Buildable Area - inside setbacks
  • Each Floor Area
    • Livable
    • Non-Livable - Garage, Storage, Utility
    • Conditioned
  • Impervious
    • (Roof Drip Line - plus Paving, etc not under the Drip Line)
  • Pervious (Landscaping and other materials that will allow water to soak in)
  • % of Lot Coverage (Bldg Footprint)
  • Floor Area Ratio (Total Floor / Property Area)
In some jurisdictions Pools and Ponds are counted as Impervious and in others they are not.
Stairways, Elevators, etc are only counted on one floor.  Open Below is not counted.
There just isn't a single solution that covers every case.
If I understand you right, this would be really easy to do just by making custom room types with a prefix or suffix "Below" and then doing a schedule that includes area from below grade room types
2 hours ago, Renerabbitt said:
one polyline for lot size and just a bunch of schedules
yeah the more I was playing with the schedules last night and got the parcel coverage going with the one global variable for the pline parcel (which like you I had already as my current macro uses/needs it), I was coming to the realization you could do it all with the schedules and OIPs. And then I was thinking today you could OIP the basement to flag it off from being included in the top two floors sq ft schedule. or like you said have a specific room type.  I like your "non livable" moniker. We call it "unfinished" up here :)
Looks like yours would cover the vast majority of cases (although I had a new one the other day doing up a house for my brother, the basement is included in the FAR if 60% of the volume is above grade. I cant imagine trying to calculate that for a walkout with different side slopes...maybe solid subtraction/intersection etc. my guess is the DA just looks at the elevations and tries to do some basic math with straight lines or just believes whatever I put down. But no one is doing this automagically with plines or schedules I dont think)
I haven't looked back at your other thread yet wrt to the schedule updating. So I need to, as that only leaves the, when I update the pline, the schedule does not update unless I go into the room DBX issue, presumably because CA has no idea the global variable is in the mix.
The only other downside is I am guessing there is no auto vertical adjustment. In your snippet, I assume if one had three floors, one would have to move the lower schedules down. or one could just have the whole think duplicated, one for bungalows, one for 2 storey and one for three storeys and just move them around on layout for whichever is needed.
But overall I think you've got the solution for the vast majority of the cases, or at least the ones I have seen.
you could do it, a polyline for area and then you need something that reports elevation reference to bottom like a geometric shape.
Looks like even simpler for those of us who do not put the basement on floor 1 and only ever put it on the same floor (0) as one can then hardcode floor 0 into the logic.
add OIP for "Above Grade Floor" and OIP for "Above Grade Area"
for floor 0 set "Above Grade Floor" to 1 (instead of zero) and for "Above Grade Area" set it to std area, except if it is floor 0 then set the area to 0. The sum similar will then group the basement with floor 1, but it does not matter as the above grade area has been set to 0 for the basement
It does get a little tricky on the foundation, where an attached garage would have stem walls but no actual real life room but has a CA room. This would not be part of the GFA, so one would need to set it to a specific room type and exclude it in the macro. It is typically denoted as "unexcavated" here, so I suppose one could key off a specific room name rather than type.
But I will say, it does look like a very clean approach for "typical" area calculations around here
Building footprints for the purposes of parcel coverage get a little complicated as height of cantilevers off the ground determine if they count or not. I suppose then cantilevers could be made into their own rooms and marked as included or excluded. But then the adjacent room label dimensions would be incorrect. Maybe a small price to pay for a relatively straight forward dynamic system
