HumbleChief Posted Monday at 06:43 PM Share Posted Monday at 06:43 PM Never really done dormers before and can't seem to get them placed where I'd like them. THANK YOU! Plan below https://www.dropbox.com/scl/fi/7xgor2a9sf8d7zihgn6vd/DORMER-1.plan?rlkey=lfsgf3gnxq9dz18zgpaykx4fl&dl=0 Link to comment Share on other sites More sharing options...
Hammer7 Posted Monday at 06:50 PM Share Posted Monday at 06:50 PM Steve Nestor is quite good at dormers. Link to comment Share on other sites More sharing options...
Michael_Gia Posted Monday at 10:00 PM Share Posted Monday at 10:00 PM 2 hours ago, HumbleChief said: can't seem to get them placed where I'd like them Don’t use auto-dormers. It’s mainly; - hole in roof - place walls - use the “lower wall type if split by butting roof” in the roof tab of the wall dbx. - use the “ballon through ceiling above” in the structure tab of the wall dbx. - manually draw your roof planes. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted Monday at 10:11 PM Solution Share Posted Monday at 10:11 PM The vaulted ceiling in the main room is forcing Attic walls to build above, blocking the dormer. Open the large room. Check Flat Ceiling Over This Room Open the broken dormer and press OK (or copy a new one over assuming you've deleted the broken one already) Uncheck Flat Ceiling Over This Room 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted yesterday at 06:00 PM Author Share Posted yesterday at 06:00 PM Thanks Tea, haven't had time to try your idea bit looks great. THANK YOU WORKED A TREAT!! 1 Link to comment Share on other sites More sharing options...
