Fun With Dormers
HumbleChief
Go to solution Solved by TeaTime,
2 hours ago, HumbleChief said:
can't seem to get them placed where I'd like them
Don’t use auto-dormers.
It’s mainly;
- hole in roof
- place walls
- use the “lower wall type if split by butting roof” in the roof tab of the wall dbx.
- use the “ballon through ceiling above” in the structure tab of the wall dbx.
- manually draw your roof planes.
  • Solution
The vaulted ceiling in the main room is forcing Attic walls to build above, blocking the dormer.
Open the large room.
Check Flat Ceiling Over This Room
Open the broken dormer and press OK (or copy a new one over assuming you've deleted the broken one already)
Uncheck Flat Ceiling Over This Room
